20 Most Recent
Black & Decker BLACK DECKER BDL153S Stud Metal Sensor BULLSEYE Questions & Answers
I need calibration instructions
This unit is self calibrating. There is no method for manually calibrating this tool. Just hold the sensor flat against the wall and depress the button. After a few seconds the unit is calibrated and you can begin sliding it smoothly across your wall to detect studs and wires.
I have a BDS 300 sensor and have lost instructions
I just bought one too and instructions need deciphering. Select wood or metal with selector switch. Put unit flat against wall. Press and hold on/off button on left. (It looks like it must be kept pressed in at all times to be 'on' and when released it's 'off). The unit with calibrate and give a beep back and lower red LED will stay on. Move unit slowly left/right and more red LEDs light up until green is on. This is 1st edge. Mark it with pencil. Move unit along until Green is off and down to single LED. Then move it back in opp. direction until Green is on again. This is 2nd edge. Attached is a scan of page from Instruction Manual. Quality is lowish as attachment limit here is 150kb.
Need user manual for w5746
Same exact features, buttons and functions as this manual by Irwin.
http://www.irwin.com/uploads/documents/36_laser_tape_25.pdf
