20 Most Recent
Craftsman 17191 19.2-volt C3 Cordless Drill/Driver 3/8 in Questions & Answers
I need the owner's manual
You can go online with Sears and get the manual via online. You can also contact customer service and they can direct you. Craftman tools have their website you should find something there
How do oscillating drill presses work? I have an
Did you already read your manual for that drill press?if your manual is available there is an instruction on how the drill press work..I think the problem their is the shaft that can be found at the right of the drill press..maybe the error is that the wiring of the shaft.
Drilling wood on a craftsman 10" drill press
There are several possibilities. I am assuming that by "hang up" you mean that the motor still runs, but the arbor, chuck, and bit all stall. I also assume that you are running the bit up and down to clear out the wood shavings from the bit out of the hole, you are using the correct amount of downward force, and that the bit is sharp. I would first check to see that there is proper tension on the drive belt. You can add a belt spray designed to increase friction for better running. I would also gear down the drill press even more to increase torque (I know you say you are running at the correct speed, but try a reduced speed). Another method is to use an auger bit or a forstner bit without pilot holes. If you are using a spade bit, you might try no pilot hole, and drill at a faster speed. I have a junk 10" drill press and have no trouble drilling 1" holes in oak.
