20 Most Recent Serfas Rx Men's Saddle Questions & Answers
What do the number guage
The etched guage is for your reference once you've set it and so you can reporoduce it if you remove the seat for any reason. You adjust, you try it out, you readjust if necessary. YOUR preferred riding position will not be found on a chart or in a manual.
5/7/2011 8:49:46 PM • Serfas Rx Men's... • Answered on May 07, 2011
My Serfas 305 headlight goes into strobe mode when I plug it in to recharge. What does that mean?
It could mean the battery needs to be replaced.
8/28/2019 9:03:56 PM • Serfas Cycling • Answered on Aug 28, 2019
I have misplaced the Manual for serfas level 2.2 and was hoping to find a replacement here.
Fixya is a place to ask people questions, not to obtain things directly. Usually the best thing to do first is search Google, but I could not find a manual for your computer that way, so I'd suggest you contact Serfas: https://www.serfas.com/contact-us I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
9/5/2017 6:44:49 PM • Serfas Cycling • Answered on Sep 05, 2017
I have a Serfas airbones
I am assuming you are trying to inflate a presta valve. If that still doesn't work, your pump may need new seals, or is damaged in some way.
11/29/2014 2:51:15 PM • Serfas Cycling • Answered on Nov 29, 2014
2answers
I bought a serfas bike
generally you have to put the pump up to the nozzle and have the lever down then put the nozzle in tightly and then pull the lever up. If after several attempts it doesn't work the pump may be broken, as bike pumps generally break easy
3/21/2014 9:18:57 PM • Serfas Cycling • Answered on Mar 21, 2014
0answers
I have a Serfas FP
If it's a simple valve model just unscrew the collar and remove the guts.
http://www.serfas.com/pdfs/FloorPumpUsage_SimpleValve.pdf
8/6/2011 12:18:09 PM • Serfas Cycling • Answered on Aug 06, 2011
0answers
0answers
0answers
I have a Serfas WFP-200
you may have a presta valve which is a different compare it to the one on your car lets say if they are the same you imple place the pump nozzle on the tube and open the lever to lock in place is indeed it is presta the have a much smaller size simple open the nozzle and flip the to pieces inside to allow the pump to be presta capable ok also you will need to screw open the presta valve before trying to pump ok if its still alittle frusterating simply bring in the pump to your local bike shop and they will be more than happy to give you the low down on the pump functions ok :) happy riding ok :)
2/23/2011 5:23:53 PM • Serfas Cycling • Answered on Feb 23, 2011
I have the bike pump
Sounds like you are doing everything right on the pump end.
The culprit is probably with the Valve. There is a small tip on the end that needs to be unscrewed to allow air in and out. Loosen up the tip and give it a couple taps to make sure it is moving freely then try again.
12/14/2010 2:25:21 PM • Serfas Cycling • Answered on Dec 14, 2010
I recently purchased Serfas Vermin
Mount 'em and ride "em. If he doesn't like the feel your only out the twenty minutes to flip it. Chances are if there isn't an arrow they are not directional.
10/7/2010 12:16:30 AM • Serfas Cycling • Answered on Oct 07, 2010
How do you reset the
ask or call the provider of this product. there should be a phone # on the manual.
8/3/2010 9:07:46 PM • Serfas Cycling • Answered on Aug 03, 2010
Serfas Rx Men's Saddle Logo
1 questions posted
Top Serfas Cycling Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Tony Parsons
Tony Parsons
Are you a Serfas Cycling Expert? Answer questions, earn points and help others
View Most Popular
Serfas Cycling
  • Serfas Cycling
Most Popular Question
number guage
  • Cycling
