20 Most Recent
MARCY Sb 240 Multi Purpose Bench Questions & Answers
For my Marcy multi purpose
Not wishing to insult you, the problem is probably you have little experience/knowledge/aptitude with nuts, bolts and mechanisms to be able to instinctively know why you can't do what the instructions say you must do.
It is quite possible the hardware pack is incorrect or the items badly made.
I suggest in the absence of friends, neighbours or relatives who are experienced/have aptitude that you take your problem to your local car repair shop.
My Marcy ME 709 is making a clunking sound. I opened the cover and the belt is not slipping off the track. I've only had it 3 months. Any ideas as to what it could be?
On my wife's machine, it was the clutch/freewheel coil spring making a chunching sound when it engaged each time. Any variation in lbs of thrust on each pedal stroke also made it crunch. This crunch is amplified through the body of the bike and becomes a clunk with each pedal stroke, and sounds just like a loose crank/ bottom bracket. I replaced the pedals to test and replaced the grease in the crank bearings/cups with Phil Wood grease, and agonized on the tightness of the cone on the crank before finding the real source of the noise. I allpied some grease to that clutch spring and worked it in a bit and there is no more clunk. Also, it is smoother in generat for my swapping out the crank bearing grease. Wife is happy. :-)
