20 Most Recent
Onkyo TX-DS595 Receiver Questions & Answers
The Onyko TX-DS595 receveiver won't respond to remote.
When unit is on hold down vcr button and press standy power button. display will read 'CLEAR". turn back on and see if remote works. note that this will erase any of your settings. Point the remote at any camera and look at the camera display. If you see a white light when you press buttos remote is working. Remove the top cover, remove front cover and resolder connections on remote receiver. If you intend to do this let me know and I can give you more details.
Can i hook my onkyo reciever upto my laptop to
u need this (search ebay.com)also u can make this cable easily.
3.5mm Mini Plug to 2-RCA Stereo Audio
Cable. plug 2 RCA jacks to (Aux in)socket on your Receiver,3.5mm Minijack to your Laptop's speaker out.select AUX input on your Receivers Remote .
Onkyo TX-DS595 with no display?
Ran my 595 blind for 2 years and finally spent the time to diagnose it this year. Turns out that one of the resistors that is on the power supply went bad. Similar problems have happened with later models so i thought the same may be true for the DS595.
My Receiver has always run fine.. just no display anymore.
Here's the fix. Replace R9501. its on the larger board that is part of the Power Supply. You will have to take the 4 large screws out of the base of the big heavy power supply block to find the resistor. I believe the old resistors is a 1/4 Watt. I replaced it with a 1 Watt so that it can handle the heat of being turned on and off better.
The resistor you will need to buy is 2.0 Ohm. I wouldn't go anything less than a 1/2 Watt and preferably 1 Watt.
My receiver works line new now!
