Volume decreaseHi, I own a receiver Onkyo Tx-SR600E, bouth in 2003. I use it just on weekends, and just ocassionally at more that 50-60...
1 Solution
overheating?Receiver has been trouble free for several years with no changes made to how it is hooked up. Lately, after listening...
3 Solutions
Reduce outputI recently notice the the output from my receiver seems to be reduced. When playing music I would have the volume set at...
1 Solution
More BassIs there some known defect w/ this unit. The Bass control really does not change the sound whether it is 1/2 way or all...
1 Solution
View All
TX-SR600suddenly, there is no sound coming out. I can test the speakers and they are fine Any suggestion
Post a Solution
Optical InputI have had a Sony DVD-CD 5 disc player hooked to the receiver with an optical cable with no problems at all until the...
Post a Solution
Specifications
Key Features
Surround SoundDolby Digital® · DTS ES® · Dolby Pro Logic II Number of Channels6.1 Channels Stereo Mode Power80 Watt @ 8 ohm, 20 Hz - 20 kHz, THD: 0.08% Surround Mode Power80 Watt @ 8 ohm, 20 Hz - 20 kHz, THD: 0.08%
Inputs / Outputs
Rear Input ConnectorsComponent x 2 · Digital Coaxial x 1 · Digital Optical x 2 · Composite (Video) x 4 · S-Video x 4 · RCA (2 Audio Channels) x 5 Surround Analog Inputs5.1 Channels x 1 Rear Output ConnectorsComposite (Video) x 2 · Component x 1 · Digital Optical x 1 · RCA (2 Audio Channels) x 2 · S-Video x 2 Front A/V ConnectionsHeadphones x 1 · Composite x 1 · S-Video x 1 · Couple RCA Jack x 1 · Optical x 1 Component Video Bandwidth50 MHz
Convenience
On Screen DisplayWith OSD Tone ControlsBass & Treble Speaker Impedance4 ohm · 8 ohm · 6 Ohm Speaker SelectionA+B or A/B
Remote Control
Dimensions
Warranty
Onkyo Contact Information
Main support number201-785-2600
Support FAX201-785-2650
Sponsored Links
