20 Most Recent Gibson KG7SA045C23A 45,000 BTU 80% Gas Furnace, 1 Stage, Multi-Speed, Questions & Answers
The component being protected by the fuse is drawing excessive current - has to be a board or something because the motor always draws more than three amps. Check the units schematic for locating the possible offending board. Must be relatively new since you indicate it is multispeed. Still under warranty?
Gibson... | Answered on Mar 01, 2015
The four flashes is failure of ignition. It could be the flame sensor dirty. The furnace tries to light four times before you get the four flashes. The board then locks out for one hour unless the power is removed and restored. You could try gently cleaning the flame sensor with fine steel wool. If you don't have fine wool you can use a crisp dollar bill.
with the burner firing the yellow flame sense indicator should be pretty much locked on or flicker briefly. If it just occasionally flashes on then the flame sensor rod needs to be cleaned.
hope this helps you.
Gibson Heating &... | Answered on Apr 10, 2018
Sounds like a over heat is holding the heat off taking to long allow a call for heat. A limit holding off .
Gibson Heating &... | Answered on Dec 23, 2017
Condination, wow that is an interesting spelling of the word Air conditioner.
Gibson Heating &... | Answered on Jun 23, 2017
Is this a gas furnace ? Newer high eff. gas furnaces do have cooler outlet temperatures. The installer should have checked the temperature rise and gas pressure. By adjusting the gas pressure and blower speed you can obtain a higher outlet temp, but you don't want the gas pressure to be higher than the manufacture specs and you don't want the furnace to run outside of the manufactures temp rise specs.
Gibson Heating &... | Answered on Mar 02, 2017
There are over temp and roll out sensors on the unit. They may be weak, or you may have a problem with flame adjustment, etc. Where did you cut that hole? The air flow has to be balanced in the room where the furnace is, if you have the furnace drawing in air from the room and not through the cold air return you run the risk of CARBON MONOXIDE being drawn out of the flue into the air feed and this can poison anyone in the structure.
Gibson Heating &... | Answered on Jan 22, 2017
i will assume you are talking about evaporator --a few reasons restricted air flow coils dirty -air filter clogging --fan not working or operating properly --low on freon ---turn fan on and with a spray bottle mix water and a little liquid soap and spray coils the fan will pull mixture thru coils keep spraying do not wipe the coils you can get injured and also damage coils an replace with new filter if still freezes over will need to check freon level and fan operation
Gibson Heating &... | Answered on Sep 11, 2016
E4 genraly is a compresses problem it could be that the start capacitor has blown
Gibson Heating &... | Answered on Sep 03, 2016
sounds as if your outside contactor bad or no 24 volts to it.
Gibson Heating &... | Answered on Sep 06, 2015
coil and drain pan needs cleaning.
Gibson Heating &... | Answered on Aug 14, 2015
bad capacitor, bad cotactor, or bad compressor.
obviously the 80 part of cap is for compressor if the motor was not changed it should still be a 5uf. new motor require different values.
Gibson Heating &... | Answered on Aug 13, 2015
if your talking water unstop drain. freon replace coil
change the fan capacitor.
fan relay stuck in & control fuse might be blown. see if you have 24 volts at outside unit.
Gibson KG7SA045C23A 45,000 BTU 80% Gas Furnace, 1 Stage, Multi-Speed, Logo
1 questions posted
Top Gibson Heating & Cooling Experts
Marvin
Marvin
Paul Carew
vince
Are you a Gibson Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Gibson Heating & Cooling
Most Popular Question
amp fuse keeps blowing
  • Heating & Cooling
