20 Most Recent
SYMA Toys industrial 2 Tail Rotor Blade Prop For Syma Skypixie Rc Helicopter Questions & Answers
The tailblade has stopped spinning. It won't go
ok take all screws out and seethe three cogs? a small one has unmeshed from the top cog. place the cog back together and then turn it on. try moving the helicopter up a bit. now it should work
1/14/2012 5:59:20 PM •
SYMA Toys...
Answered
on Jan 14, 2012
SO33G charger over heat ,
It is no use to buy a new charger if the problem is a short. Indications are that it is. When the batteries are in need of replacement and wont charge up, overheating of the charger will also occur.
1/3/2018 11:10:24 AM •
SYMA Toys...
Answered
on Jan 03, 2018
Syma so33g lower blades do not rotate
wrong!!! if the bottom set of blades aren't turning its because the drive gear for that shaft is loose and is spinning on the shaft instead of spinning the shaft itself. try tightening the screws but make sure the screws are lined up with the holes in the shaft so they seat otherwise your going to strip the plastic gears threads. if that doesnt work then you will have to replace the gear and shaft. its a cheap part and readily available. only problem is youll have to take apart almost the entire heli to get the old one out n the new one in. the gear comes pre-mounted on the shaft. Buy 2 or 3 of them right away as you will have to replace it just about every time your heli tips over while the blades are turning. the screws only go into the shaft about a 16th of an inch and is easily stripped out
12/26/2012 8:25:07 PM •
SYMA Toys...
Answered
on Dec 26, 2012
I Just bought a Syma
You need to assign the remote to the copter, turn on copter then remote, push forward on throttle then back, light on remote will stop flashing and remain static, there we go ready to fly have fun great machine.....
12/9/2011 11:59:12 PM •
SYMA Toys...
Answered
on Dec 09, 2011
