20 Most Recent
2000 Chevy Astro - Passenger van, with factory roof rails - Base Rack System Questions & Answers
Tsb bulletins
My first guess would be the speed sensor on the way out.
Coolant leak on top of engine.
You will need to pull the beauty covers off the top of the engine and you should be able to see the leak. I am not sure what size engine you are asking about but if the coolant is running out as soon as you put it in there must be a stream of water coming out of the leak. Just guessing it must be a rubber hose either from the radiator or the heater hoses. Hope this helps.
Our 2000 astro van spits and sputters when gas is applied but smooths out when given gas. Over all runs ******, what is wrong?
Clean the Mass Airflow Sensor with the proper cleaner spray, perhaps it has become contaminated and isn't sensing airflow properly. Any holes torn or worn into the air duct tube from the MAF sensor to the throttle body will give any engine a fit. All intake air MUST come through the MAF sensor (and not leak in past it somewhere). Another possibility is the throttle position sensor (the throttle body) isn't working properly. A diagnostic check of stored or pending trouble codes should be read from the computer and used as a guide to assist troubleshooting the problem.
Mounting 250 Combibox on Land Rover factory rails
Ronald, sometimes thing just don't happen like the book says so in times such as this I have been known to bring out the mig welder and fabricate a mount that will work and the modifications shouldn't be noticed from the topside of the vehicle. Be sure to use suitable materials 3/16th inch wall mild steel and that proper prep work and proper welding procedures are observed and you will have the box serve you well for years to come.
