20 Most Recent Little Tikes Endless Adventures Look Out Mountain Climber Questions & Answers
Have a Little Tikes Endless Adventures Mountain
Regards, Tony
5/17/2011 2:40:57 AM • Little Tikes... • Answered on May 17, 2011
Little Tikes (vintage) Ride-On Train doesn't drive forward?
Question edited for clarity. Question moved from Cars and Trucks category. If it runs backwards, then the problem but be the forwarding part of the controller. Usually your local Model Shop will know a repairer, or they might undertake it themselves. ..
10/20/2023 6:49:26 PM • Little Tikes... • Answered on Oct 20, 2023
Does the Little Tikes Country Cottage door fit the Little Tikes Imagine Sounds Playhouse?
Try the company direct.
Little Tikes ' Replacement Parts
Little Tikes https://parts.littletikes.com Little Tikes makes toys that last. Shop available replacement parts for your Little Tikes toys. View Little Tikes parts here. ‎Little Tikes 7' Trampoline · ‎Ride-on Toys
5/19/2023 4:58:36 PM • Little Tikes... • Answered on May 19, 2023
Little Tikes Tumble Train. But now it only turns on, run for about 5 or 6 sec, then shut off. Put new batteries in but still does it whether on track or off. I hate to get rid of it. Any ideas?
Question moved from Cars and Trucks. This says it is only supposed to run for 30 seconds, so it must have some sort of timer, perhaps in the chimney stack. The other possibility is that the electric motor needs cleaning and lubricating. If you have a Model Shop near you, they normally do repairs or know someone that does. It is a $90 toy so worth repairing! START/STOP BUTTON With fingers away from track, press top of smoke stack to start and stop train. (Train will move for 30 seconds then stop. Press smoke stack to start train again.)
657559 Little Tikes Tumble Train
3/18/2023 1:37:56 AM • Little Tikes... • Answered on Mar 18, 2023
2answers
Are assembly instructions for the
Yes they are, this is what I got of the little tykes website, it's the ADOBE instructions, 62451R100-2-06.pdf
I hope it will be of help, have a great day :)
10/19/2020 2:34:12 AM • Little Tikes... • Answered on Oct 19, 2020
Where can I find replacement doorbell/phone for little tikes imagine sounds playhouse
Unfortunately Little Tikes does not carry replacement parts for the 4089 ImagineSounds Interactive Playhouse, as you can see in the provided link. I have, however, included the Instruction Manual, which includes the part numbers. I think for these parts you will have to search on sites like Amazon or Ebay. https://www.littletikes.com/mas_assets/media/pdf/4449-Imaginesounds-Playhouse.pdf
4/18/2020 2:50:55 AM • Little Tikes... • Answered on Apr 18, 2020
I need to find the yellow window shutters for the little tikes log cabin. Any suggestions
They might have it in the stores, but chances are slim. Then go online to see if you can find the part. If not there go to the company and they will send you the part you need. Or tell you where you can get the part.
6/12/2019 12:43:45 PM • Little Tikes... • Answered on Jun 12, 2019
Can I get a copy
You can get the instructions at:
http://www.littletikes.com/pdf/4332JungleClimber.pdf
Thanks for using Fixya.
4/19/2019 2:46:08 PM • Little Tikes... • Answered on Apr 19, 2019
FINDING A 6V LEAD ACID BATTERY FOR LITTLE TIKES TRIKE RIDE ON
Amazon or ebay has great list
3/1/2019 7:12:07 PM • Little Tikes... • Answered on Mar 01, 2019
3answers
Trying to disassemble little tikes log cabin to no avail!!! Even searching you tube it appears such hard work and almost impossible to dismantle! Any ideas?!?
I figured out this problem today. I was ready to get a torch and saw to get it apart. It looks so simple and everything says no tools required. If your like me and bought it used, you don’t even know how it went together to reference from. So, start with the roof it’s easy to remove. For the walls I used a crowbar and brut strength. I turned it onto the back wall side. So the door should be facing up to the sky. Now, get the crowbar or something to use to get in between the roof log and the side wall log. Now pry up on the roof, push hard! The wall will slide up and break free from it’s locked together position. I quickly rejoiced and was happy when I Hurd the thunk and saw the wall moving a bit. I pulled up on the wall and quickly went back into frustration mode. But don’t fear, this is where the brut strength come in. I stepped on the wall flat on the ground and got my shoulder under the wall facing the sky. I stood up, my shoulder pushing the top wall and bam ??! One of the side wall logs jammed into the top wall came loose. After that I just kept doing the same thing and eventually was able to disassemble the rest. Two people may make this easier but I had just me and my two year old.
Tools needed: Pry bar and a strong shoulder
12/17/2018 10:16:34 PM • Little Tikes... • Answered on Dec 17, 2018
Looking for replacement decals for Little Tikes Lightning McQueen cars bed.
Hi there are some Thomas the tank decals on E/BAY...cheers
8/14/2018 5:30:50 AM • Little Tikes... • Answered on Aug 14, 2018
LIttle tikes push tricycle wheel trend replacement?
notify manufacturer or online search using the make and model
5/8/2018 12:58:43 PM • Little Tikes... • Answered on May 08, 2018
Little tikes push trike, tread on tires slides off?
use double sided tape or little bit of glue
5/8/2018 12:55:31 PM • Little Tikes... • Answered on May 08, 2018
Looking for manual/replacement sun roof for little tikes mini van or station wagon circa 1988 from what i found
Search ebay for a 1988 toy, and see what you can find.
4/23/2018 6:39:40 PM • Little Tikes... • Answered on Apr 23, 2018
Little Tikes Yamaha Rhino 660 Ride on Car - User Manual
Hi Gabe. try this link out and scroll down the page you might find the manual. Little Tikes Yamaha Rhino 660 Ride on Car User Manual Google Search
11/5/2017 7:05:45 PM • Little Tikes... • Answered on Nov 05, 2017
Replacement parts for 619212 Little Tikes Double Duty Engine & Workbench.
Go to manufacturer for parts.
8/31/2017 10:04:35 PM • Little Tikes... • Answered on Aug 31, 2017
Little Tikes Endless Adventures Look Out Mountain Climber Logo
2 questions posted
Top Little Tikes Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Steve Pack
Steve Pack
Are you a Little Tikes Toy Expert? Answer questions, earn points and help others
View Most Popular
Little Tikes Toys
  • Little Tikes Toys
Most Popular Question
little tikes endless adventures mountain
  • Toys
