20 Most Recent Lowrance HDS 5 X Sonar () Questions & Answers
Check the mounting and cable connection of the transducer on the stern. If loose will tilt during movement, in reverse wakes from the prop. CAREFULLY check unit during these conditions. The transducer needs to be completely submerged. Good Luck.
Lowrance HDS 5 X... | Answered on Jan 13, 2012
Need to contact the manufacturer for support on this. It may not be fixable.
Lowrance Boating | Answered on Jun 10, 2019
Probably time for a new one. Harsh conditions like on a boat causes the electronics to fail after awhile
Lowrance Boating | Answered on Jun 05, 2019
Check the Positive and negitive terminals It may not be seeing the voltage it needs , I have a strike 7 and it did a similar thing , as soon as the load from the transducer is on it wont load ,, Mine was the dirty Neg cable to the bus bar under the dash
Lowrance Boating | Answered on Apr 24, 2019
To many possibilities. Low voltage, problem with hydraulic pump, no voltage on hydraulic pump, broken wire, heading sensor etc
Lowrance Boating | Answered on Feb 02, 2019
Loss of depth reading over 15kph, is usually caused by either turbulence from under the chines of the boat, or that the transducer is toe up, or back end up. If the transducer throws up spray, it is back end up. Toe up is harder to see. Get someone to drive the boat and look overboard. The transducer needs to be flat at the speed you want to see the information, and of course that changes depending it you are trolling or on plane and your trim.
Not marking fish could be a faulty transducer or that the sensitivity setting is not set high enough. Read the manual. I am a Humminbird person :>)
Lowrance Boating | Answered on Dec 30, 2018
here is the manual
HDS-5, HDS-7, HDS-5m & HDS-7m - Lowrance
https://www.lowrance.com/.../Lowrance.../HDS-5-7-5M-7M_OM_EN_988-10041-00...Sonar references do not apply to the HDS-5m and HDS-7m GPS only units. Manual Conventions. When you are instructed to press a button in this manual, the ..
Software Upgrades here
Lowrance HDS 5 Software Google Search
and finally Mapping
mapping for Lowrance HDS 5 Google Search
and specifically, INSIGHT
Insight Genesis - Download free Lake, River and Coastal Maps
https://gofreemarine.com/insight-genesis/Make your own maps and download free maps from the community. Insight Genesis' cloud-based software does all the work, automatically processing ... with sonar signals from your existing Lowrance, Simrad or B&G transducer. ... The cloud automatically backs up all your data, protecting against lost or damaged SD cards.
Lowrance Boating | Answered on Nov 13, 2018
Press Waypoint Waypoint, you should only use MOB as a temporary mark.
Lowrance Boating | Answered on Oct 08, 2018
Try Googling (Lowrance)(5)(manual) without parens.
Lowrance Boating | Answered on Jul 26, 2018
Lowrance HDS 5 X Sonar () Logo
1 questions posted
Top Lowrance Boating Experts
Bob Peloquin
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
View Most Popular
Lowrance Boating
  • Lowrance Boating
Most Popular Question
got hds 5 im getting bad or false sonar
  • Boating
