20 Most Recent Texas Instruments TI84Plus Graphic Calculator Questions & Answers
Easiest way to find any command or button is 2nd then 0. Opens the catalog of every command. hit the up arrow until you find it.
Hope I helped.
Texas... | Answered on May 29, 2017
features. Press "2ND" "STAT PLOT", select 4:PlotsOff, and press ENTER.
Texas... | Answered on Sep 13, 2014
TI calculators have an annoying habit of dimming the screen, especially when the batteries are changed, so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible. Does it?
If you go too far, press and release the 2ND key, then press and hold the down-arrow key.
Texas... | Answered on Dec 07, 2013
how to set a calculator in normal mode from scientific mode
Texas... | Answered on Nov 05, 2012
The TI-84 is limited to numbers with at most twelve significant digits.
If you must know the EXACT value of 16!, try this. Calculate 14!. Note the two zeroes at the end. Strip them off by dividing by 100 and remember the two zeroes. Multiply by 15. Strip off the last zero by dividing by 10 and remember that we've now stripped off three zeroes. Multiply by 16. Add the three zeroes at the end to get a fourteen-digit number.
In this particular case the result is exactly what you get by using the FACT function. That's also true for 17!, but it breaks down past that because 18! has more than twelve significant digits.
The whole point of the calculator is to allow you to do calculations with a reasonable degree of accuracy, as opposed to exactly. You'll notice that it can't do a simple operation like dividing 1 by 3 and produce an EXACT answer---only a twelve-digit approximation.
Texas... | Answered on Oct 03, 2012
Contrary to what you may be thinking, parentheses are necessary to ensure that calculations are performed as intended. If you were using stacked fractions that may lift some ambiguities, but since you are not using parentheses anything goes.
Here is one interpretation of the expression. I am quite sure you will not be able to find it without inserting the necessary parentheses.
Texas... | Answered on Mar 29, 2012
Unfortunately there isn't a solution to get them back, other than re-downloading them from where you got them originally. Re-download them, and then load them onto your calculator using a USB-A to USB-B connector. This can be done through the included software program that came with your product. I hope this helps! - Omn1cide
Texas... | Answered on Mar 05, 2011
There should be a WINDOW button or key when looking at the graph. Hit that button and the screen should show the x min, x max, x scale, etc. From here you can change the x-min and x-max to whatever you would like. Same is true for the y values. Default is -10 for x and y min and 10 for x and y max with both having a scale of 1.
Texas... | Answered on Mar 01, 2011
Use the round() function in the MATH NUM menu. For example, to round 1/7 to three digits, press
MATH right-arrow 2 1 / 7 , 3 ENTER
Texas... | Answered on Jan 26, 2011
Texas Instruments TI84Plus Graphic Calculator Logo
17 questions posted
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Steve Allison
Steve Allison
Ekse
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Texas Instruments Office Equipment & Supplies
Most Popular Question
daughterss calculator got wet when
  • Office Equipment & Supplies
