Set alarm on Centrios for 4 am
There are many models of Centrios brand alarms.
Here is some advice found on the web
1:
All buttons are on the back of the clock. To set the time zone, push "menu"; then push "Set" until the correct time zone is displayed (EA = Eastern, PA = Pacific, etc); then push "Menu" again - DONE. To adjust time, date, year & day, push & hold "Set" until the hour begins to flash; then push "Adjust" until the correct hour is reached; then push "Set"; repeat this sequence as the clock moves on to the next flashing segment (e.g. minute, seconds, month, date, & year); the clock will automatically set the Day based upon the Month, Day & Year you select - DONE.
2:
Press theSETkey to enter the mode"Manual Time Setting".
Manual Time Setting
In case the Skyscan Atomic Clock is not able to detect the WWVB-signal (disturbances, transmitting distance, etc.), the time can be manually set. The clock will then work as a normal Quartz clock.
Note:
In 12 hours mode the time will be displayed with an additional"PM"for the time from 12:00 noon until 11:59.
1. The hour digits will start flashing on LCD1. Set the desired hours by pressing the+key followed by pressing theSETkey.
2. Now the minute digits will start flashing. Set the desired minutes by pressing the+key . If the + key is held, the units will increase by 5.
3. Press theSETkey to move to the"Year Setting".
