20 Most Recent Juki MO6714 Mechanical Sewing Machine Questions & Answers
Bartack machines skipping
Hello Keith, From the little information you stated, I can only take a stab at what might be wrong with your machine. I suggest you make sure the take up spring is working freely and properly.
3/27/2014 4:03:28 AM • Juki MO6714... • Answered on Mar 27, 2014
0answers
Juki skipping stitches
completely un-thread the machine and rethread it in this order. Upper Looper, Lower looper, right needle Left needle. It has to be in that order ALWAYS. If you break a thread... un thread and start the threading process again. If rethreading doesn't work... change the needle that is skipping. Good luck
8/16/2012 3:46:22 AM • Juki MO6714... • Answered on Aug 16, 2012
I change the news blade
hi there,
which blade you change? upper or lower one?
for lower one just make the top surface for blade aqual with throat plat.
for upper lower turn handwheel to make blade at lowest position in that time the upper lower must be lower than lower blade by arround 2.5mm and keep in your main the two blade also must be very close no space between it.
best regards
ashraf abozid
[email protected]
CAIRO - EGYPT
8/26/2011 1:51:34 AM • Juki MO6714... • Answered on Aug 26, 2011
0answers
Question about Juki Overlock MO-6704 Someone
Hi, yes I believe that will work, however you may need to re-adjust several time to get it perfect, my wife ( who's owned a couple industrial machines agrees ) use some scrap material to make adjustments and if possible ( with machine unplugged of course ) turn by hand to make sure it is not too far and could jam. I hope this was useful, please write back to let me know-even if not so we may try to help some more. Thanks for asking FixYa, and good luck-Prodzilla
4/26/2011 5:05:57 PM • Juki MO6714... • Answered on Apr 26, 2011
When the seam is tested, from the right side of
Try turning the upper tension higher, if its set to 4 then try 6 or so. Make sure its threaded correctly as well.
Derek
1/21/2011 6:03:44 AM • Juki MO6714... • Answered on Jan 21, 2011
Hello, please give me the juki support link.
https://jukiamericas.com/pages/supportif you live in the USA or https://jukiindustrial.co.uk/support/ for the UK and Europe.
3/24/2024 12:14:48 PM • Juki Sewing... • Answered on Mar 24, 2024
3answers
I have a new juki DL 8700 and the fuse keeps blowing off. Initially, the machine ran for almost 3 hours until fuse blown off.
You should make sure it is grounded. Also, is it getting oil from the pan? Blown fuses usually mean there is an overload in the motor. Check that the belt is not too tight.
2/18/2024 8:57:59 AM • Juki Sewing... • Answered on Feb 18, 2024
I need the user manual of JUKI flora 5000 home sewing machine
Juki flora 5000 manual parts details
2/6/2024 4:03:20 AM • Juki Sewing... • Answered on Feb 06, 2024
How to thread a Juki DDW-122I
See Jiku Website. You can download the required manual by giving type of machine, model number etc. Juki-Manuals (jukilanka.com) There are more than 400 manuals on this site. You can find your required manual. Juki manuals
1/17/2024 3:10:18 PM • Juki Sewing... • Answered on Jan 17, 2024
Model SC-1-EB; error code E41545713
Sc1 error 26 code 1769160
12/16/2023 8:56:26 PM • Juki Sewing... • Answered on Dec 16, 2023
Juki HZLG210 sewing machine. Why does it cut thread while sewing?
I am not familiar with this particular machine, but I found references to the thread cutter. Did you try turning it off? Could the cotton thread be rotten, have you tried sewing with button thread? Thread Trimming Function correlates with the scissors icon on the face of the machine. The G210 in unique in the fact that it has this function, which will automatically trim the thread for you, leaving virtually no mess! This one is a life saver as it relives you from having to spend time cutting and cleaning loose threads! The text above was from here https://www.instructables.com/Juki-Sewing-Machine-1/ More here https://www.google.com/search?q=Juki+HZL+G210+trimming+thread+while+sewing ..
11/18/2023 11:56:37 PM • Juki Sewing... • Answered on Nov 18, 2023
Juki Jureve HZL-010. What type of memory card is it using please?
Question edited for better English. It appears to be an old style Floppy Disk. https://www.google.com/search?q=juki+jureve+hzl-010+memory+card
11/10/2023 5:22:09 PM • Juki Sewing... • Answered on Nov 10, 2023
Juki MO6714 Mechanical Sewing Machine Logo
13 questions posted
Top Juki Sewing Machines Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Juki Sewing Machines
Most Popular Question
bartack machines skipping
  • Sewing Machines
