20 Most Recent
Husqvarna Huskystar 207 Sewing Machine Questions & Answers
Twin needle
Hello
Install the second spool pin.
Place the two spools on the spools pins, one on each spool pin.Make sure that the spools are spinning toward each other.
Thread as for single needle.
Thread each needle from a different spool.
Caution: Make sure that the stitch width is not wide than the twin needle maximum swing. Check that the needles will not hit the throat plate as they swing from left to right and back again on stitches with width.
Happy twin needling
Sewingirl/
3/20/2017 12:43:30 AM •
Husqvarna...
Answered
on Mar 20, 2017
Bobbin thread jams
try changing the needle--flat side goes to the back of the machinecheck the thread take up lever & see if the thread is still on itit's also possible that the machine is out of time & needs to serviced
3/30/2015 3:26:01 AM •
Husqvarna...
Answered
on Mar 30, 2015
How do I thread the machine
look in your owners manual or take the machine to a Viking dealer and they will show you how to thread it.
3/15/2015 8:20:46 PM •
Husqvarna...
Answered
on Mar 15, 2015
How do I oil a sewing machine
there is not any placed for a user to oil a 207. if your machine is having problems, take it to your authorized Viking repair dealer.
2/9/2015 1:51:41 AM •
Husqvarna...
Answered
on Feb 09, 2015
The thread gets caught up in bobbin area
This mess is commonly referred to as a bird's nest or 'birdnesting' and it's usually caused by incorrect top tension and that's often caused by the top thread not in the correct path. (For me, I occasionally forget to thread through the take-up lever.) A damaged needle can also cause birdnesting.
2/8/2015 6:19:23 AM •
Husqvarna...
Answered
on Feb 08, 2015
How to correct huskystar 207 stuck in reverse?
Could possibly have the reverse feed checked by a professional - it is possible the machine got wet in the metal parts, and is rusted up or clogged up from too much oiling! NOT a quick easy fix
7/16/2014 4:20:34 AM •
Husqvarna...
Answered
on Jul 16, 2014
