20 Most Recent
Wahl James Martin Collection ZX595 Stainless Steel Electric Blades Grinder Questions & Answers
Schaerer SCP is not rinsing correctly
Check the Operating Temperature:
Ensure that the machine has reached the correct operating temperature. If it hasn't, the indicator light will be on. Wait until the machine is fully heated before proceeding.
Check for Ongoing Programs:
If a rinse or cleaning program is currently in progress, the cleaning button may be flashing. Wait for any ongoing programs to complete before trying to brew coffee.
Inspect the Brewing Unit:
Make sure the brewing unit is properly seated and not obstructed. The brew group should be in the correct position.
If the brew group overflows, it could be due to a blockage or misalignment. Remove the brew group, clean it thoroughly, and reinsert it properly.
Inspect the Coffee Spout and Drainage Area:
Check the coffee spout for any clogs or blockages. Clean it if necessary.
Examine the drainage area at the bottom of the machine. If water is running away onto the floor, there may be a leak. Inspect the drip tray and other components for leaks or damage.
Refer to the Operating Manual:
Consult the operating instructions manual for your Schaerer Coffee Club machine. If the above do not resolve your issues, you may have to contact Schaerer Services.
De'Longhi PrimaDonna Soul Coffee Maker not making milk foam.
The milk delivery tube is very narrow bore and in my experience you will find the tube is blocked with congealed milk solids even if you clean then regularly. You need an enzyme milk cleaner like Rinza and even with that you need to manually massage the tubes or remove the blockages. The service engineers just replace them.
What does a CIMBALI M34 CODES ERROR 053 mean?
That .depends on software and configuration. It is not a universal code You might find help in the manual.
CIMBALI M34 SELECTRON USE AND INSTALLATION Pdf Download ' ManualsLib
Inspect Electrical Supply: Ensure that the machine is receiving proper electrical power. Sometimes, an interruption in the power supply can trigger error codes.
Clean Components: Check if any components related to coffee grounds or filters are dirty or clogged. Clean the underpan gasket, filter holes, and filter holder outlet hole.
Coffee Ground Quality: Verify that the coffee grounds are of the correct consistency. If they are too coarse or too old, it can affect the machine's operation.
Discharge System: Examine the discharge system for any blockages.
