20 Most Recent
Cuisinart DBM8 Electric Burr Grinder Questions & Answers
My Cuisinart CCJ-500P1 won't turn on how to repair
To repair it, one must find out what the cause is.
Do some fault finding first; check there is power at the switch and the motor has continuity etc.
When you have found the faulty part, then you can replace the faulty part or repair the break in the cable etc.
Cuisinart coffee maker.... clock light does not light
Switch it off and wait 10 minutes: Sometimes, if your coffee maker is still new and has water sitting in it for a long time, or if you have just cleaned it, you might see an error message saying that there is no water. Just turning them off and waiting 10 minutes will often solve the problem. Afterward, turn it back on, pour some water into it and try again! If for some reason it doesn't work after doing that, try the next steps mentioned below.
Reset the clock, then brew a cup of coffee: Check to make sure all of your connections are properly secured and tight. Even a half-turn can cause problems with appliances that use electricity, and it is important to remember not to force any connection into place. You may need a new plug for an appliance that's been in service for many years if you are having trouble getting power to it-don't assume anything! Many older appliances have worn or damaged wiring.
Turn it off and on again: The next logical step is to turn your coffee maker off and then back on again. This works with many small appliances and just might clear up whatever issue you're experiencing. In some cases, a reset button or power button will be present to make it easier. If not, try to turn it off at its power source (i.e., unplugging it) and then plug it back in afterward. If that doesn't work, try turning off your home's circuit breaker for a few minutes, if applicable, before returning power to it and trying again.
If these tips do not work, you might try the customer service of the manufacturer.
My Cuisinart Grind and Brew does not brew. Cannot clean or descale since the water or solution does not pass thru.
Check Water Reservoir: Ensure that the water reservoir is properly seated in place and filled with water to the appropriate level. Sometimes, the machine won't brew if it detects an inadequate water level. Check Water Inlet and Outlet: Inspect the water inlet and outlet for any clogs or blockages. Sometimes, debris or mineral buildup can prevent water from flowing through the machine. Clean any visible obstructions carefully. Descale the Machine: If the issue is due to mineral buildup, descaling the coffee maker might help. Use a commercial descaling solution or a mixture of equal parts water and white vinegar. Run this solution through the machine as you would during a regular brewing cycle. Afterward, run a few cycles with plain water to rinse out any residue. Inspect Grinder and Filter Basket: Check the grinder and filter basket for any coffee grounds or other debris that might be obstructing the flow of water. Ensure that the grinder and filter basket are correctly positioned and securely locked in place. Clean the Brew Head: The brew head may also become clogged with coffee grounds or oils, affecting water flow. If your machine has a removable brew head, take it out and clean it thoroughly. If it's not removable, follow the manufacturer's instructions for cleaning the brew head. Run a Cleaning Cycle: Some coffee makers have a cleaning cycle that helps remove buildup inside the machine. Refer to your user manual for instructions on how to activate the cleaning cycle. Reset the Machine: In some cases, a simple reset can resolve minor issues. Turn off the coffee maker, unplug it from the power source, wait for a few minutes, then plug it back in and try brewing again.
Check the tubes: Make sure the tubes are sitting in the right place and filled to the correct level. Sometimes the machine will not make alcohol if it senses that there is not enough water.
Cuisinart DGB-900bc clean basket notice won't turn off.
I also own a Cuisinart DGB-900BC. This is how I fixed the sensor issue.Disclaimer: IF YOU ARE UNSURE OF MY INSTRUCTIONS USE A MULTIMETER OR TESTER TO ENSURE YOU AREN'T MODIFYING THE WRONG WIRES WHICH COULD RESULT IN ELECTROCUTION IF DONE IMPROPERLY.Over time the basket tends to sag, which prevents the little sensor from contacting it for the unit to realize the door is shut. The sensor is a spring loaded piece of plastic hanging from the underside of the coffee maker which makes contact with the basket when it closes. If you're looking straight on it is to the left.What you'll have to do is either find a way to fix the basket sag, force the sensor closed, or do what I did and modify the unit.Sensor modification:You will need a size 10 security bit with the hollow center (not just a plain star bit) screwdriver to take the four screws out of the bottom to reveal the wires you need to modify. There are two blue wires that go to the top of the unit which are crimped onto two black wires. The two black wires lead to the circuit board which is extremely difficult to get to on this model. All you have to do is snip those two black wires and install a push button which keeps the circuit closed until you push it. Initially I thought twisting them together would work but this unit will not brew coffee a second time unless you remove the basket and toggle the sensor input. So I basically have to unplug the unit and plug it back in to reset that. I will be adding the push button soon.Ensure you buy the right push button. You need one that keeps the circuit closed until you push it, most push buttons keep the circuit open until you press them. Alternative is to buy a metal toggle switch, preferably one that spring loads back to the center after you push it.To summarize:1) Fix basket sag or wedge sensor to closed position.OR1) Remove bottom plate of coffee maker2) Snip the blue wires leading to the sensor and add a push button or toggle switch on the two black wires they were connected to. Mount switch externally so you can push it to fool the unit to think you removed and replaced the basket.My attached picture shows my temporary twisted wire solution with yellow connector before I added the push button. Note that while I'm holding the blue ones leading to the sensor, the two small black wires are what's important. I did this modification before making an account here.
My cuisinart coffee maker shuts off after brewing cycle. What. Do I do to fix this oroblem
Believe it or not, this frequently happens when there is calcium scale build-up in your coffeemaker's water line. The coffee make will make it through the brewing, but then shut off if it thinks the flow was too slow--which is nearly always due to built up calcium scale.
All you have to do is run a few pots of white vinegar through your coffeemaker to get all the scale out of the waterline; I'll usually mix half water, half white vinegar and run the brewing cycle (no coffee in it, obviously). You'll see the scale come out in your coffee filter. You can run the same pot of water-vinegar mix several times, and then run a couple of extra pots of *fresh water only* to rinse out the descaling vinegar mix from the water line.
Voila! your coffeepot will start working again just like it should.
Cuisinart model DCC-690. Water filter for it please?
I'm sorry to hear that you're having trouble finding replacement water filters for your Cuisinart DCC-690 coffee maker.
After some research, it appears that the DCC-690 model does not have a specific water filter that is designed to fit it. However, Cuisinart does offer a universal water filter that can be used with any of their coffee makers.
The Cuisinart DCC-RWF replacement water filter is a universal filter that is compatible with all Cuisinart coffee makers that have a water filter. It is designed to remove impurities from tap water, such as chlorine, calcium, and other minerals, to improve the taste and quality of your coffee.
You should be able to find this filter on Cuisinart's website, or at a retailer that sells Cuisinart coffee makers and accessories. It is important to note that the filter should be replaced every 60 days, or after brewing 60 pots of coffee, whichever comes first.
I hope this helps!
Have cuisinart ss10 coffee maker I have descaled with 2 gallons of white vinegar and the descale light won’t go out. How do I get it cleaned ?
I recently had the problem of the dreaded "de-scale" message coming up on my coffee maker. After descaling my coffee maker 3 times, the "de-scale" message wouldn't go away. I called the Customer Service number and was told to unplug the coffee maker for an hour and that should re-set the machine. I did that and still the de-scale message remained. Another phone call and another customer service representative and I was told to hold down the Hot Water and Rinse buttons together. I placed a large mug and hit the buttons. There was a good bit of water that came through but IT WORKED! The coffee maker is as clean as can be and working very well. I suggested to the Customer Service Representative that Cuisinart should include this in the instruction and troubleshooting section. But I doubt that will happen. Sad that the web site info is not updated. Wanted to share my experience so it might help others frustrated by this issue.
