20 Most Recent GE WES1384SMSS Stainless Steel 1000 Watts Microwave Oven Questions & Answers
The glass plate has to be correctly seated on the drive spindle before you can have any hope of reliable rotation. Place the plate on the spindle and spin it gently until it seats.
GE WES1384SMSS... | Answered on Feb 15, 2018
It's likely that the magnetron has burnt out.
GE WES1384SMSS... | Answered on Mar 23, 2015
It's probably the magnetron, unfortunately.
I presume the info is not in the owner manual---Google the model number with "replace lamp (or bulb or light) to see what you can find.
GE WES1384SMSS... | Answered on Nov 02, 2012
Hi Angela, as a first step disconnect the device from the outlet, then you must remove the lid and see how accessible it is to clean it
Remove all the liquid, clean and let it dry very well
I hope you can solve the problem
Regards Franco Dosil
Hola Angela, como primer medida desconecta el aparato del tomacorriente, luego deberas sacar la tapa y observar que tan accesible esta para limpiarlo
Retira todo el liquido, limpia y dejalo secar muy bien
Espero puedas resolver el problema
Saludos Franco Dosil
GE Microwave... | Answered 2 days ago
Hi Toan, first question is how old is the microwave? If it is less than 5 years with no other problems, then yes it's worth fixing. If it's older than 5 years or has other minor problems it might not be worth it. Check the cost of new before fixing and call a repair company in your area to compare prices. Hope that helps.
GE Microwave... | Answered on Sep 05, 2019
My initial guess is that the thermo fuse is blown. Simple to replace, only need a Phillips screwdriver. Heres a YouTube video describing how to proceed.
https://youtu.be/HV4SJA-_N_c
GE Microwave... | Answered on Jul 03, 2019
Request the repair manual directly from GE.
GE Microwave... | Answered on Jun 30, 2019
Assuming your model number is actually PEB2060SM2SS, this (like most counter top models) requires remvoal of the outer wrapper / cover, then you will be able to see and remove the control panel screw from the rear of the control panel frame.
But more importantly, why do you want to remove it?
If you'll let me know your symptoms, I can help you determine what the problem and solution would be.
In FixYa doesn't notify me, you can e-mail me directly at [email protected]
You can find helpful exploded views and find part numbers here:
https://www.geapplianceparts.com/store/parts/assembly/PEB2060SM2SS?ModelType=ModelType
Probably the best source for affordable microwave parts is here: http://tinyurl.com/gv383.
GE Microwave... | Answered on Jun 21, 2019
Check your limit switches and or safety switches that will cut you out every time. Good luck
GE Microwave... | Answered on Jun 02, 2019
GE WES1384SMSS Stainless Steel 1000 Watts Microwave Oven Logo
Popular Tags
13 questions posted
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
Jimmy
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
GE Microwave Ovens
  • GE Microwave Ovens
Most Popular Question
motor turntable working fine but
  • Microwave Ovens
