20 Most Recent Sharp R930AW Microwave Oven Questions & Answers
It's probably a bad door switch or door switch mount, probably the top one, which is the door sensing switch.
We have the actual service manual for this model and have uploaded it to our site for you here.
You can order Sharp parts from
Encompass here or from the Sears Parts Direct Web site.
Sharp R930AW... | Answered on Jan 16, 2011
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sharp R930AW... | Answered on Sep 15, 2010
It's not worth fixing, you are looking at $90 for repairs
Sharp R930AW... | Answered on Jun 12, 2010
You should check for 3 volts on sec coil supply for magnetron but do this check with the hv capacitor and hvr disconnected if 3volts is present , most probably your magnetron is deffective, replace it with the same type
Sharp Microwave... | Answered 18 hours ago
it's probably not the microwave then.
what else have you got nearby which might be beeping.?
Some battery-powered devices such as smoke detectors will beep to tell you the battery needs changing.?
Sharp Microwave... | Answered Yesterday
Clean the temperature sensor in the cavity.
Sharp Microwave... | Answered on Aug 28, 2019
Sounds like a door latch needs an adjustment that only a qualified technician can perform for safety reasons.
Try unplugging uni t for 10 seconds,then plug back in. If that doesn't work, contact a technician. For service.
Check your users manual for installation instructions. then reverse engineer them.
Line Fuse
If too much current passes through the microwave circuitry, the line fuse will blow. If the line fuse blows, the microwave won't start. To determine if the line fuse is at fault, use a multimeter to test it for continuity. If the fuse does not have continuity, replace it. In addition, you should investigate and resolve the problem that caused the fuse to blow. If you don't resolve the underlying issue, the new fuse will blow too. (Caution: The microwave oven can store thousands of volts of electricity in its high voltage capacitor, even after the microwave oven has been unplugged. Due to the potential for electric shock, it is extremely dangerous to replace the electronic components in a microwave. Only a licensed technician should replace the line fuse.)
Sharp Microwave... | Answered on Aug 01, 2019
Consult users manual for programming instructions
visit www.repairclinic.com for manuals on
your particular model.
Sharp Microwave... | Answered on Jul 01, 2019
the little motor under the table is toast
Sharp Microwave... | Answered on Apr 17, 2019
Sharp R930AW Microwave Oven Logo
5 questions posted
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Ekse
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Microwave Ovens
Most Popular Question
when shut microwave door light staays
  • Microwave Ovens
