20 Most Recent Frigidaire FGMV185K Microwave Oven Questions & Answers
Frigidaire Gallery Microwave making a new
If this is new, return to the place of purchase, causes, defective magnetron, bad inverter board, and possibly keypad control board.
5/21/2012 9:56:43 PM • Frigidaire... • Answered on May 21, 2012
We heard a zap in
may be a shorting door switch and/or wiring to it.
8/4/2011 2:16:40 AM • Frigidaire... • Answered on Aug 04, 2011
Is there a reset button on frigidaire microwaves.
nope sure isnt, if it doesnt turn on you may have just blown either the load in fuse or the high voltage fuse down the bottom, remove the cover should be a couple screws round the outside and check fuses if you know how (MAKE SURE ITS UNPLUGGED FROM THE POWER FIRST) (NEVER START THE MICROWAVE WITHOUT THE METAL COVER ON AS THIS ACTS AS A RADIATION SHIELD)
5/4/2011 12:38:37 AM • Frigidaire... • Answered on May 04, 2011
My Frigidaire Galaxy microwave came on by itself - very hot and fan running. I could not shut it off It was. Purchased in January, 2017.
My 2021 Frigidaire also turned on by itself 2 days ago. It also got hot and would not turn off except at the breaker. After 10 minutes I turned breaker on and the microwave was still on. Turned breaker on the next morning and all good. We are afraid to leave house unless we turn breaker off. Any suggestions? Do I need a new microwave?
11/8/2023 7:46:32 PM • Frigidaire... • Answered on Nov 08, 2023
Frigidaire Gallery Microwave. When I plug it in, it powers on and does not come off.
I would check the door switches.
10/10/2023 6:39:34 AM • Frigidaire... • Answered on Oct 10, 2023
My frigidaire microwave #fpbm3077rfa key pad stopped working, clock is on but no buttons works
The control board probably has failed.
10/8/2023 3:16:11 AM • Frigidaire... • Answered on Oct 08, 2023
My Frigidaire gallery convection microwave keeps blowing its fuses
fuses inside oven, sure. (i had to guess) all UWAVE do that when the 3 or 4 door switches CONTRADICT. this is so it does no cook a persons eyeballs.(no really ) what we do is replace them all as a set, 4x5=$20 set. I am on my 3rd set here, ( 18 year span) so i even bought a new whole spare fuse panel (behind the controller) with new switch set pre loaded.all -in- one fix. then when it fails i can replace it all in 30min flat. mine is built in fancy uwave and do not want top put in any alien Uwave here and now wood cabinets must be modified. see? good luck,
2/25/2023 1:03:49 PM • Frigidaire... • Answered on Feb 25, 2023
Frigidaire FFMV164LS 1.6 Cu. Ft. Over-The-Range Microwave. Hello, Can you turn off the turntable on Frigidaire FFMV164LSA? The manual doesn't specify.
Question edited for clarity. No you can't. The turntable needs to rotate the food or the microwave energy will burn holes in your food. The rotation spreads the heat evenly throughout the food. You can test it by removing the turntable and put a plate on the base with a pound of butter on it. Microwave on full power for a minute. Notice the holes?
2/8/2023 8:54:14 PM • Frigidaire... • Answered on Feb 08, 2023
Frigidaire pleb27m9ecd built in oven/microwave. The oven works fine. The plug on the oven that microwave plugs into is not working.
It sounds like you may have an issue with the plug that connects the microwave portion of your Frigidaire PLEB27M9ECD built-in oven/microwave to the electrical supply. Here are a few things you can try:
  1. Check the power supply: Make sure that the oven/microwave is properly plugged into a working outlet and that the circuit breaker is not tripped.
  2. Inspect the plug: Look for any visible damage on the plug and make sure that the connections are secure.
  3. Check the wiring: Make sure that the wiring inside the oven/microwave is not damaged or loose.
  4. Test the outlet: Using a multimeter, test the outlet to see if it's providing power.
  5. Test the microwave: If you have access to a known good microwave, you can test the plug by plugging it into the known good microwave and see if it works.
If none of these solutions work, it's likely that there is an issue with the electronic control board or the plug itself, which will require professional repair. It's best to contact the manufacturer or a professional technician for repair. They will be able to diagnose the issue more accurately and repair it.
1/18/2023 6:53:01 AM • Frigidaire... • Answered on Jan 18, 2023
My Frigidaire Microwave GLMV168 is giving me a F3 Code
F3 means the key pad is faulty. Probably replaceable if you can find a service agent in your area/town/city/country.
7/20/2022 3:04:50 PM • Frigidaire... • Answered on Jul 20, 2022
Frigidaire Gallery microwave. The internal light stays on and internal fan stays on when the door is closed.
Try cutting the power to it for 15 minutes to effect a power reset to the mainboard. It is still does it, you need a service call or a new one. It is a known issue. https://www.google.com/search?q=Frigidaire+Gallery+microwave.+The+internal+light+and+internal+fan+stays+on ..
6/20/2022 10:11:40 PM • Frigidaire... • Answered on Jun 20, 2022
2answers
Can the beeping be turned off on the Frigidaire microwave model mmfv162lmb.
The sounder is an integral part of the control board.
5/12/2022 2:45:49 PM • Frigidaire... • Answered on May 12, 2022
2answers
My Frigidaire over the range microwave keeps blowing the fuse when I try to start it?
I had the same problem with this POS microwave. Bought it September 2019 and the plastic at top is brittle and breaking plus the door latch springs are WAY too stiff for this application. I'm 6'4" and it is hard for me to open and close. The spring tension causes the latches to slam down on the thin edge of the plastic catch causing divot wear. The INCESSANT beeping when food is done is worse than nails on a chalkboard plus there are Way too many levels and button presses to simply soften butter or cream cheese! What a TOTAL mess that I Absolutely regret buying! As for this issue with the blown fuses (on a 20 AMP circuit with nothing else on it); I read about replacing the switches so that is where I started but it didn't work. I noticed the wear in the latch catch so I ordered a replacement and that fixed the problem. I also found a video showing how to remove the door and change the latch. I did not need a new latch, but I did want to replace the spring. I have a box of springs at home and found one that was slightly shorter but the same diameter. It had about half the pull strength and now the door opens and closes reasonably! I hope this helps
4/13/2022 1:56:45 PM • Frigidaire... • Answered on Apr 13, 2022
2answers
Frigidaire FMV158FMB caused a wet rag to catch on fire
Time for a new one!
2/22/2022 6:29:45 AM • Frigidaire... • Answered on Feb 22, 2022
Frigidaire Microwave Internal Light Bulb - HELP NEEDED PLEASE!
You are lucky! MICROWAVE OVEN LIGHT Remove the louver per instructions 1-3 above and charcoal filter, if used. 1. To replace light bulb, first disconnect power to the microwave oven at the circuit breaker panel or by unplugging. 2. Open light cover located behind filter mounting by carefully pulling up on the front edge. 3. Remove old light bulb and replace only with equivalent watt bulb available from parts distributor. Bulbs are also available at most hardware stores or lighting centers. DO NOT USE BULB LARGER THAN 20 WATTS. 4. Replace the microwave oven light cover by carefully pushing into place. Replace the charcoal filter, if used. Push the louver back into place (engaging both the bottom and top tabs) and replace the louver mounting screw. When in doubt, refer to the manual :>D https://d1vofmza27mmhi.cloudfront.net/product-pdf/frigidaire-fgmv174kf-use-and-care-manual.pdf ..
1/30/2022 2:58:31 AM • Frigidaire... • Answered on Jan 30, 2022
2answers
My frigidaire over the range microwave keeps blowing the fuse after pressing start. I need help determining where the problem is and how to fix it.
Microwave Ovens contain dangerous voltages that ARE lethal! Could be magnatron , diode pack, capacitor, contaminated turntable motor or even a faulty door switch.
1/7/2022 6:18:45 PM • Frigidaire... • Answered on Jan 07, 2022
I can't find the fuse type for Frigidaire microwave FMV156DC in the manual. Anyone know the specs of the fuse I need?
The fuse is on the main control board and is not something that is routinely replaced. Are you sure you are not looking at the thermal cut off? Parts for Frigidaire CFMV156DCD: Oven,cabinet Parts - AppliancePartsPros.com
10/20/2021 11:07:13 PM • Frigidaire... • Answered on Oct 20, 2021
Frigidaire FGMV185K Microwave Oven Logo
Popular Tags
6 questions posted
Top Frigidaire Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Jerry Naidoo
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Microwave Ovens
Most Popular Question
frigidaire gallery microwave making new
  • Microwave Ovens
