20 Most Recent
SpaBerry 2 Person Portable Spa Color: Strawberry Questions & Answers
What do I do when 32 keeps flashing on the controller?
32 is the temperature that water freezes at in farenheight scale , the controller is telling you that y0ur tub is in danger of freezing up , as this will damage its internal parts and such if this occurs , also if this tends to be a false notice (proven by a separate probe) then it could be telling you that temp control device inside the controller is having a problem , and its warning you that your tub could freeze up
Pump won't work on low setting
Most multi-speed motors have have a winding that is connected in as many locations are there are speeds. (two speed - two connection points, etc.). It is possible the the low speed portion of the circuit (the switch, wire, any connections between switch & motor) has failed. You can check out the switch with a meter to see if there is continuity from the common terminal thru the low speed terminal. Then, continue to the motor itself. The motor should have a wiring diagram on it that describes how to wire for speeds, directions, etc.It may also be an open low speed winding in the motor. It happens. I strongly caution against testing for power on the tub. It is too easy to suffer an electric shock working around a pool / spa. You should be able to test with an ohm meter and power OFF.
What is chemistry?
Chemistry is the branch of science concerned with the substances of which matter is composed, the investigation of their properties and reactions, and the use of such reactions to form new substances.
3/17/2024 4:06:29 AM •
Pool & Spa
Answered
on Mar 17, 2024
Virtual Pool 3. I need serial number for it please.
Free of charge from here. It is 23 years old, license expired.
https://virtual-pool-3.en.uptodown.com/windows
4.5/5 ยท My Abandonware
Description
Virtual Pool 3 is a 3D, first-person sports video game that simulates various cue sports, developed and released for Windows and PlayStation by Celeris. The game features 15 pool disciplines, snooker, and two varieties of carom billiards. Wikipedia
Platforms: Microsoft Windows,
PlayStation Portable,
Playstation
Initial release date: November 14, 2000
Mode:
Multiplayer video game
Genres:
Sports video game,
Simulation Game
Developers:
Celeris,
Digital Mayhem
Publishers:
Interplay Entertainment,
Sony Interactive Entertainment,
2K Play,
XS Games,
Gametapes LLC
Series: Virtual Pool..
1/10/2024 12:18:45 AM •
Pool & Spa
Answered
on Jan 10, 2024
