20 Most Recent
Tefal Pro Express GV 8120 Iron Questions & Answers
The iron of my steam generator does not heat up
I had the same problem. You need to disassemble the iron itself. From memory there are two torx screws near the cable entry and there is also one under the coloured part on the handle at the switch. Yo need to take off the cover to get to it. Once you get the iron apart you need to get to the base element. On the top of it is a bimetallic switch element. I discovered that I had some carbon build up between the contact points of the switch. I cleaned these (no need to remove) with some contact cleaner and rubbed lightly with fine grade sandpaper. Reassembled and has been working fine since
7/9/2014 11:34:42 AM •
Tefal Pro...
Answered
on Jul 09, 2014
