20 Most Recent
Morphy Richards 40708 Iron Questions & Answers
My Morphy Richards steam generator iron is intermittent with steam.
If your Morphy Richards steam generator iron is experiencing intermittent steam and you suspect a blockage in the hose, here are some steps you can take to address the issue:
- Check the water tank: Ensure that the water tank is filled with clean water and that the water level is adequate. Low water levels can affect steam production. If necessary, refill the water tank.
- Examine the steam settings: Verify that you have selected the appropriate steam settings on your iron. Some models have different steam intensity levels, so make sure you have set it to the desired level.
- Check for blockages in the hose: Disconnect the hose from the iron and inspect it for any visible blockages. Use a long, flexible brush or pipe cleaner to gently clean the inside of the hose and remove any debris or mineral deposits that may be causing the blockage. Ensure that the hose is securely reattached to the iron after cleaning.
- Clean the steam vents: Over time, steam vents on the iron's soleplate can become clogged with mineral deposits or fabric fibers. Use a cotton swab or a soft brush to clean the steam vents, removing any buildup that may be obstructing the steam flow.
- Perform a thorough descaling: While you have already used white vinegar for descaling, it's possible that there are still mineral deposits causing the blockage. Consider using a commercial descaling solution specifically designed for steam irons. Follow the instructions provided by the manufacturer of the descaling solution to effectively remove any scale or deposits that may be affecting steam production.
- Contact customer support: If you have tried the above steps and the issue persists, it may be best to contact Morphy Richards customer support for further assistance. They can provide specific troubleshooting steps or advise on potential repairs or service options.
Remember to always follow the manufacturer's instructions and safety guidelines when cleaning and maintaining your steam generator iron. If you are unsure or uncomfortable with any aspect of the troubleshooting process, it's recommended to seek professional assistance to avoid potential damage or injury.
