20 Most Recent Breville Fresca BES860 2Cup Coffee Maker Questions & Answers
  1. Turn machine off.
  2. remove group head (portafilter)
  3. place single or dual cup filter in group head.
  4. place rubber bung in group head.
  5. place one tablet in space in bung.
  6. replace group head in machine.
  7. This is where the instructions lead you astray.
  8. DO NOT PRESS 1 & 2 CUP BUTTONS SIMULTANEOUSLY WITH POWER BUTTON.
  9. Press & hold 1 & 2 cup buttons simultaneously, on their own.
  10. Now press the power button while still holding the 1 & 2 cup buttons.
  11. Cleaning cycle will start, and will take around 5 mins to complete. Book says it will beep 3 times when finished haven't heard this yet. Just wait a couple of minutes extra and all should be well.
  12. Clean me light should be out and tablet disolved if not repeat steps again until tablet disolves.
Breville Fresca... | Answered on Mar 03, 2019
According to the instruction manual, you are supposed to put the little rubber insert into the portafilter, and a tablet in the center. Then, turn the machine off. Simultaneously, hold the one shot, two shot and power buttons fro 3 seconds. The cleaning cycle is supposed to last for 5 minutes, and then the machine is supposed to beep, indicating that it's finished. Finally, rinse the portafilter thoroughly. HOWEVER, I can't get the 5 minute cleaning cycle to work properly... anyone have success with this?
Breville Fresca... | Answered on Dec 02, 2018
IF YOU CAN TRY TAKING IT APART THERE MAY BE SOMETHING STUCK IN SIDE.OF A BLADE MAY BE LOOSE. OR TRY DOWN LOADING A MANUL FROM YOUR COMPUTER USING THE NAME OF PRODUCT THE MODLE NUMBER.
Breville Fresca... | Answered on Jan 21, 2015
The hose going from the tank to the spout may have a split or not be seated correctly. Check that.
Breville Fresca... | Answered on Nov 14, 2014
These are available on line. Just search Breville, then enter the model number, and it should provide you with all the info you need.
Breville Fresca... | Answered on Oct 04, 2014
The grind is too coarse or the tamping is too light, or a combination thereof. Use some bathroom scales to get your tamping pressure right and then adjust the grind accordingly.
Breville Fresca... | Answered on Sep 25, 2013
Just had this replaced by a electronics repairer. There are two screws needed to be removed to take the top off first. One under the tamper, the other near the steam wand. Once they're out (and after removing the 6 out of the back) apparently you can take the back off to replace the water seal :)
Breville Fresca... | Answered on Jul 26, 2013
water flow very little have cleaned machine but stil the same, also what is the allen key for?
Breville Fresca... | Answered on Jun 26, 2013
Breville Fresca BES860 2Cup Coffee Maker Logo
75 questions posted
Top Breville Coffee Makers & Espresso Machines Experts
Ekse
superdad1976
Gene Pitts
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Breville Coffee Makers & Espresso...
  • Breville Coffee Makers & Espresso...
Most Popular Question
achieve normal pressure only using dual
  • Coffee Makers & Espresso Machines
