20 Most Recent Electrolux Ultrasilencer Green Canister Vacuum Questions & Answers
http://smallappliances.electroluxusa.com/en-US/Customer-Support/
download free your instr manual and see your problem lid why not close, go to the section troubleshooting.
God bless you
Electrolux... | Answered on Sep 28, 2012
Hi There,
Ok so i am going to assume you are talking about an Electrolux filter that is basically a rectangle shape with a hard plastic outer and folded corrugated filter material in the middle. The link I put to Electrolux filter would be a good example. Basically I would caution you against washing it. I know the packaging says that it is washable but what I have found is that the pores of the filter material are too fine for water to pass through. What will happen is that the vacuums suction will wedge tiny bits of dirt and dust in the pores and water will not necessarily flush it out. What is far more likely to happen is that it will wash out a fair amount but leave a portion in the filter to set and therefore continue to block suction.
You are better to use an air compressor or simply tap the filter out on a piece of newspaper and change it every year or so.
Of course if your filter is more like a Electrolux UltraActive filter which is basically foam then you simply rinse it out like a kitchen sponge and make sure it is bone dry before putting back in the machine.
Electrolux... | Answered on Jun 27, 2012
Hello see the video below for help otherwise for about 20 bucks take it to as local shop Changing belt on an Electrolux upright vacuum
Electrolux... | Answered on Apr 26, 2019
Take your OHMs elect tester check for continuity. one. PUT two wires together and test the other two one at a time check for all 000 on meter all 000 means those go together and complete circuit.. Wire it up. No tester go to browsemanuals.com and find your'es
Mike
Electrolux... | Answered on Mar 25, 2019
Request the wiring diagram for Model 1401-B directly from Electrolux.
Electrolux... | Answered on Feb 26, 2019
On top of the machine from the back the top comes off. Just push from the back on the top and it should come off. The filer is under the top. Hope this helps. Chris
Electrolux... | Answered on Feb 20, 2019
Electrolux Ultrasilencer Green Canister Vacuum Logo
Popular Tags
3 questions posted
Top Electrolux Vacuums Experts
Marvin
Marvin
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Electrolux Vacuums
  • Electrolux Vacuums
Most Popular Question
clean washable electrolux filter
  • Vacuums
