20 Most Recent Eureka 3276AZ Pet Lover Bagless Upright Vacuum Questions & Answers
Unlike most vacuums, this one the screws are on the top of your base. There are two screws one on each side. When looking at the front of the vacuum right side screw is located above the s in 12amps and on the left side screw is located above the p in pet. Now keep in mind it's not directly above the letters look about 2 inches up. Unscrew them, take cover off. Once you have done that pull up on the brush rod. Maybe tough if ur vacuum has a lot of built up dirt. Next put belt on metal prong then put on brush rod. Place rod back in its spot, gonna need little bit of muscle. Then put top back on and replace screws. Plug in flip bottom just to make sure brush is spinning. If u have followed steps this should work. I hope this helped took me forever to find the screws because I have always had vacuum with them on the bottom and internet was no help to me. Good luck
Eureka 3276AZ... | Answered on Aug 17, 2016
1. Pry off adjustable clear cover with flathead screwdriver.
2. Unscrew 2 Philips screws holding power paw together.
3. Place tips of needle nose pliers into the two holes on each of the black round pieces on the ends of either end of the roller. Twist and the black pieces will release.
4. Remove roller, use needle nose pliers or awl to dig out any hair wrapped up in the roller or especially the ends of the roller at the metal pins.
5. Replace belt and put everything back together in the same order you took it apart.
Eureka 3276AZ... | Answered on Dec 30, 2014
They are all pretty much the same..You should See four or so screws that hold the cover of the vac to the bottom where the beater brush is..once that is removed you will see the motor with a small round shaft and the beater brush that comes out. The belt stretches between the motor shaft and the beater bush pulley.. Once the belt is on make sure the beater brush is in place on both sides and replace the top..you should be good to go..good luck..
Eureka 3276AZ... | Answered on Dec 06, 2014
Your filter is clogged. Open the tank. Unscrew the filter. Slide the casing off the filter. Brush out the collected dirt. If it's really clogged you can wash it, but use warm water to break up the packed dust. I wouldn't wash the inner filter more than once or twice. Make sure it's completely dry before you reassemble it. Easier, but more expensive, replace the filter.
Eureka 3276AZ... | Answered on Mar 04, 2014
You have to turn the vacuum over and remove the two small silver screws on the sides of the bottom plate.
Mine did the same thing. The electrical cord is loose where it plugs into the machine. When you pull the vacuum into the room it puts just enough strain on the cord to break the electrical connection. Push the plug on the cord firmly into the vacuum.
This link is for the manual it will give you full instructions on page 4
http://www.eureka.com/FileLibrary/7f8e42f94c4146dea58673f01e6464a7/en_80509_OwnersManual.pdf
Eureka 3276AZ... | Answered on Sep 15, 2013
I had the same problem with exact same vacuum, was working great and the one day just lost almost all suction in the hose and in very very poor suction on base when vacuuming carpet, also when vacuuming the carpet everything I vacuum shoots out the bottom and hits my feet, never happened b4, checked all hoses and tor apart every thing to see if their war dust in motor, clogging anywere but nothing everthing looked great, NEED HELP CANT AFFORD TO BUY ANOTHER VACUUM OR TO TAKE TO REPAIR MAN TO B CHRGED AN ARM AND LEG, SOMEONE PLEASE HELPPPP!!!!!!!!!!
Eureka 3276AZ... | Answered on Sep 09, 2013
this link is for the manual it will give you full instructions how to change belt and filters....Enjoy..
Eureka 3276AZ... | Answered on Dec 01, 2012
Eureka 3276AZ Pet Lover Bagless Upright Vacuum Logo
79 questions posted
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Eureka Vacuums
  • Eureka Vacuums
Most Popular Question
overheating shuts off
  • Vacuums
