20 Most Recent Samsung RFG297AABP (285 cu ft) Side by Side Bottom Freezer Refrigerator French Door Questions & Answers
sounds like ice tray over filling
Samsung... | Answered on Jun 03, 2015
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
I'm
including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Samsung... | Answered on Aug 24, 2011
If its leaking same part needs replaced.The water valve at the bottom rear of fridge
.I'm including my article on Refrigerator Repair for your help and convenience.;
Leo Ponder
imufo2
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Samsung... | Answered on Jul 28, 2011
Hi.
If the leak is not too big, then water comes from condensation. Water condensing inside the fridge is supposed to be conveyed toward the drain hole inside the fridge. From there the water should normally go to the drain try located in the compressor assembly.
What usually happens is that the drain hole gets clogged with frozen water, and the condensed water ends at the bottom of the fridge. The problem is fixed defrosting the fridge. In some sporadic case it is necessary to remove drain hole blockage using a thin and flexible drain rod.
Do a complete defrost, that should fix the problem.
Here all parts and diagrams for this fridge.
Regards.
Ginko.
Samsung... | Answered on Apr 15, 2011
Check the water pressure or any filters in the water line or a crimp in the supply tube. Also make sure you totally defrost where the water enters the ice maker.
Samsung... | Answered on May 10, 2019
Check the seals all the way around the door for dirt or foreign particles. Also see if the latch is loose or misaligned.
Samsung... | Answered on May 09, 2019
Samsung RFG297AABP (285 cu ft) Side by Side Bottom Freezer Refrigerator French Door Logo
15 questions posted
Top Samsung Refrigerators Experts
Paul
Gerry Harvey
Gerry Harvey
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Refrigerators
Most Popular Question
refrigerator not cool freezer working
  • Refrigerators
