Troubleshooting & Support
Hot Topics:
- Refrigerator
- water dispenser...
- change water...
- change filter
- LFX23961
- 226
- repair
- noise
- fan
- ice maker red
- remove
- water
- fridge
- power
- water...
- slow water flow
- fridge door
- french door
- remove icemaker
- hot
- 106
- ed25dq
- door french ...
- running...
- cold
- water dispenser
- drain pan...
- french
- condenser fan...
- remove water...
- View All »
Problems & Solutions
low water flow
Make sure the hose behind the fridge is not kinking up, slowing down the flow rate of water.
The Lg Refrigerator doesn't cool.
Hi, Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can...
Why is water leaking from under LG model LFX28978
cracked or misaligned drain pan usually just dirty and out of alignment from being moved
where are the error codes on the refrigerator
Does your LG have a digital display? It should be on the display somewhere. What is the Model #?http://www.ehow.com/list_6318472...
My water feed tube at the bottom of the freezer...
Instead of replacing the entire tube, have you thought about repairing the break? They sell spice kits at most home supply stores like...
on my LG top freezer
The drain in the freezer behind back lower panel needs opening. You can see it at the bottom of the back panel underneath the evaporator...
Refrigerator model GR-B247WV Bottom of freezer
Hi, You may have a blocked drain. Therefore when your fridge goes into a defrost cycle, the melted water usually travels down a drain hole...
Bottom Freezer model, LFD23860st, Freezer
NOTE: This is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem But the solution is in...
Our refrigerator stopped working after
The water inlet tube in my LG GR208DVQA
Hi DavidT-FR, If I can advice you first to check the Inlet Valve to see if it is indeed faulty. Remove the Inlet Valve but keep the pipe on...
LG express cool no frost
I had the same problem - repairman was just here - it was the defrost motor was burnt - the freezer had frost buildup behind the panel,...
My LG refrigerator Model No:
My LG refrigerator makes sounds
Hi there, Can you please advise: 1) what model LG fridge do you have (look for the manufacturer's label)? 2) when the door panel lights...
i want know what (er
Hi, all of the codes that indicate malfunctions or similar problems will be shown with an "Er" on the digital display. The LG...
My refrigerator is model LFX25950TT
Some sort of fan problem in the ice making unit. See page 32
See all LG LFX23961 (226 cu ft) Bottom Freezer French Door Solutions
Unsolved Problems
Defrost mode not working
Frost/ice build up occurs around freezer vents causing fan/motor to vibrate. Requires monthly manual defrosting. Any...
LG refrigerator LFX23961 not cooling
This frig is not cooling. It's been less than 2yrs since I bought it from Sears. Sears' warranty says I have to...
I have just purchased a
I have just purchased a condo thatw as never occupied but is 2 years old. The condo has an LG French door/bottom mount...
See all LG LFX23961 (226 cu ft) Bottom Freezer French Door Problems
Manuals & Guides
TopDo you have a manual for LG LFX23961 (226 cu ft) Bottom Freezer French Door Refrigerator? - Upload it to FixYa!
Upload a manual for LG LFX23961 (226 cu ft) Bottom Freezer French Door Refrigerator
Specifications
TopKey Features
Full Product Name:LG LFX23961 (226 cu ft) Bottom Freezer French Door Refrigerator
Total Volume:22.6 cu. ft.
Refrigerator Type:Refrigerator
Energy
Energy Efficiency:Energy Star Compliant
Product MPN
MPN:LFX23961SW
What's your problem?
Fix-O-Meter
276
276 people have viewed this product
- 8 people asked about this product.
- 2 people found solutions for this product.
- 2 people have added this product.
Pins on the...
How to fix your...
Ice Maker...
