Troubleshooting & Support
Hot Topics:
- water dispenser
- control panel...
- ice maker...
- icemaker
- cooling
- control panel...
- ice maker
- water collects...
- lsc27910
- ice maker not...
- Refrigerator
- stick
- freezer
- water drips...
- temperature
- water filter
- lg 265
- remove water...
- manual
- ice
- water
- water dripping
- remove drip pan
- tromm dle2516w
- defrost timer
- fix
- filter
- side
- wf t1081tp
- th c43 ipod
- View All »
Problems & Solutions
WHERE IS THE WATER FILTER IN THE LSC27910
Hello George,The filter is located in the ceiling of the refrigerator compartment in the upper right side,it twist 90 degrees in a clockwise...
Water not filling ice tray
NOTE: This is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem But the solution is in...
my lg refrigerator just gave out. Its plugged in
I had this problem a while ago. It may not be the circuit breakers but the outlet where fridge is plugged may have gone bad. Plug fridge...
sticks water does not stop
Hi. I has lg refri sometimes water keep running none stop .Do you know what wrong? Thankyou...
at the bottom of the
thats probably the defrost water hitting the defrost heater (the heater comes on about every 8 hours and melts the frost on the evaporator...
ice maker make noise and back of freezer is frozen
THE DEFROST CONTROL IS OUT MAY BE THE DEFROST BYMETAL OR A TIMER OD DEFROST HEATER WHAT BRAND AND SIDE BY SIDE OR TOP AND BUTTEM REF. AND...
Weve had our LG frig almost 2 years. We just
Hi, There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the...
Why is water leaking from under LG model LFX28978
cracked or misaligned drain pan usually just dirty and out of alignment from being moved
where are the error codes on the refrigerator
Does your LG have a digital display? It should be on the display somewhere. What is the Model #?http://www.ehow.com/list_6318472...
My water feed tube at the bottom of the freezer...
Instead of replacing the entire tube, have you thought about repairing the break? They sell spice kits at most home supply stores like...
on my LG top freezer
The drain in the freezer behind back lower panel needs opening. You can see it at the bottom of the back panel underneath the evaporator...
Refrigerator model GR-B247WV Bottom of freezer
Hi, You may have a blocked drain. Therefore when your fridge goes into a defrost cycle, the melted water usually travels down a drain hole...
Bottom Freezer model, LFD23860st, Freezer
Our refrigerator stopped working after
The water inlet tube in my LG GR208DVQA
Hi DavidT-FR, If I can advice you first to check the Inlet Valve to see if it is indeed faulty. Remove the Inlet Valve but keep the pipe on...
See all LG LSC27910 (265 cu ft) Side by Side Refrigerator Solutions
Unsolved Problems
My LG LSC27910TT freezer wont freeze and frig wont...
The front panel buttons dont work right I can raise the temp but after a while the temp control lights go out
We own the LG, LSC27921ST frig for about over a...
We own the LG, LSC27921ST frig for about over a year. And the ice maker is quit working recently. I have check all the...
stopped working
Outlet has power but refridgerator stopped working. No lights inside or at control panel.
LG refrigerator (LSC27910) sticking water lever
The water lever of my LG refrigerator (model: LSC27910) gets stuck and water overflows. I opened the front exterior...
LG Refrigerator, Model LSC27910SW. Ice maker only
LG Refrigerator, Model LSC27910SW. Ice maker only spits our crushed ice. Cubes are in the tray, but when I push the...
I have LG side by
I have LG side by side mod#LSC27921 no water coming out, selenoids working fine. Bak of the door the plastic bulging,...
the light globe has gone in fridge how do i get
the light globe has gone in fridge how do i get cover off
My water dispenser sticks! I push the water
My water dispenser sticks! I push the water dispenser to get a glass of water, pull it out, and the water won't shut...
See all LG LSC27910 (265 cu ft) Side by Side Refrigerator Problems
Manuals & Guides
TopDo you have a manual for LG LSC27910 (265 cu ft) Side by Side Refrigerator? - Upload it to FixYa!
Upload a manual for LG LSC27910 (265 cu ft) Side by Side Refrigerator
Specifications
TopKey Features
Full Product Name:LG LSC27910 (265 cu ft) Side by Side Refrigerator
Total Volume:26.5 cu. ft.
Fresh Food Volume:16.23 cu. ft.
Freezer Volume:10.24 cu. ft.
Installation:Built-in
Total Number of Shelves:4
Refrigerator Type:Refrigerator
Dimensions
Overall Depth:35.25 in.
Overall Height:69.75 in.
Overall Width:35.75 in.
Warranty
Warranty:1 Year Parts and Labor
Convenience
Exterior Color:Stainless Steel
Extra Features:Adjustable Rollers / Levelers
Defrost:Automatic Defrost
Controls / Display:Digital Display
Fresh Food Compartment
Fresh Food Shelves / Bins:Vegetable Bin (Controlled Humidity) x 1
Shelf Material:Glass
Door Opens:Opens to Left and Right
Light:Yes
Freezer Compartment
Shelve / Bins:Shelves x 3
Ice Maker
Ice Maker:With Ice Maker
Dispenser:Ice
Energy
Number of Motors:1 Motor
Amperage Rating:15 Amp.
Product MPN
MPN:LSC27910SW
What's your problem?
Fix-O-Meter
2,251
2,251 people have viewed this product
- 33 people asked about this product.
- 7 people found solutions for this product.
- 3 people have added this product.
Pins on the...
How to fix your...
Ice Maker...
