20 Most Recent
KitchenAid KEHU309 Stainless Steel Dual Double Oven Questions & Answers
I dont know how to use the oven properly. when i
There should be a plus/minus sign OR a up/down arrow to adjust the temp.on the control/touch panel. The default setting is usually 350 and can adjusted up or down accordingly,the display starts at 120 and is supposed to rise as temp. increases.
The bigger issue though is to have it serviced and see why it doesnt rise above 200
Gene
KitchenAid Superba oven will not
the latch the hooks into the door is caught inside the slot where it locks into when in self clean,you have to move the latch,unplug it,look through the air vents or slots up above the door if you can get a screw driver in there try to move the latch or if you can get something down inside to move the latch,i used a plastic long wire tie to do this before,i slid the tie down around the metal hook part of the latch that locks into the door,and pulled it to the left and got the door to open,it got hung up in the hole and the door wouldn't open but what ever works you have to move the hook part of the latch to get the door open,you can try picking up on the door to see if you can get it open or you'll have to pull the oven out and take the top off to get at the latch,hope this helps
My Kitchen Aid Superba Oven
Hi, my name is Audrey. I am a KitchenAid employee and would appreciate the opportunity to assist you with your oven. Please send me an email through our customer service address,
[email protected] and type 'Attention: Audrey' in the subject line. Please include your full name, phone number, and model and serial number, and I would be happy to try to help resolve the situation with your appliance.
