20 Most Recent
Kelvinator KFS220RHY Freezer Questions & Answers
Left the door open for 2 hours
The evap coil is likely frozen over from running 2 hours straight.
Defrost it for 24 hours, and re-try. Inspect that the evap fan is operating properly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
KFS220RHY Is this freezer good for frozen foods as
Good day,
No reason it wouldn't work fine. It should be noted that if your in a grocery store the freezer sections used to store ice cream are separate from those for normal produce.
The reason is the ice cream is normally kept 15 degrees colder.
However, this unit has an adjustable tstat that should get you around the ideal 0 degree range.
As well, it's designed to be rugged not as energy effecient as a standard domestic freezer.
Do some gave the instruction manual for the Kelvinator FD830 Freezer. I am not sure how to set the temp on it?
Locate the Temperature Control Knob: The temperature control knob is typically located inside the freezer compartment. It allows you to adjust the temperature settings.
Understanding the Knob:
For Top Mount ™ Models: The temperature control knob is usually located in the refrigerator section. At higher altitudes (e.g., 1000 meters above sea level), set the refrigerator temperature control to one-half setting warmer than MID.
For Bottom Mount (BM) Models: Adjust the refrigerator temperature using the bottom knob.
Setting the Temperature:
Turn the knob clockwise (usually towards the "colder" side) to lower the temperature.
Turn the knob counterclockwise (towards the "warmer" side) to raise the temperature.
Adjusting the fridge compartment temperature may cause a small change in the freezer temperature.
Remember to allow some clearance around the freezer for proper ventilation.
Is a Kelvinator upright considered energy efficient?
freezer --no
every time you open the freezer door , the cold air is dropped to the floor so the unit has to work hard to bring the temp back down same as any up right freezer
fridge --it is as efficient as the rest
