20 Most Recent Quasar SP-3231 TV Questions & Answers
I have a friend with a quasar SP-3231 television
The set you are talking about I am unfamiliar with .. however as an engineer for 23 years I am sure it is not unlike any other CRT TV as you say you have no voltage on the rgb is the tube heater on ( you should see a glow at the end of the tube ) if not check you heater rail voltage , check your oscilator Ht output transistor should be 300 to 360 volts on the emitter if this goes down then the lineoutput satge will not opperate hence no picture and in many cases the audio is fed from the secondry of the Line output transformer hence no sound either .. DO NOT ATTEMPT TO DO THIS UNLESS YOU HAVE HAD TECHNICAL TRAINING VOLTAGES HERE ARE IN EXCESS OF 19 KV to 25,000 Volts DEPENDING ON TUBE SIZE AND SHOULD NEVER BE ATTEMPTED BY UNTRAINED PERSONEL... Vortash
5/12/2009 10:02:06 AM • Quasar SP-3231... • Answered on May 12, 2009
What remote will work with Quasar SQ4001
the one stated in the free sq4001 manual or a relic universal remote , rare i bet.
7/25/2022 11:57:33 PM • Quasar Televison... • Answered on Jul 25, 2022
2answers
1977 CRT TV wont turn on
Not sure why anyone would want to repair a non hd TV as the picture quality isn't usable with modern content but if you're doing it because you like restoring something vintage here are some ideas. Some CRT sets use a pulse from the back side of the flyback transformer as a starter voltage supply, it needs this short pulse to start the power supply, it's kind of like starting a gas motor, the starter only runs for a short time then the gas motor takes over, this signal needs to be measured with a scope or a high end meter, this was a common issue with a lot of older CRT sets that use this type of power supply. I'd look at the start up supply as without that the regular supply isn't operatable.
7/25/2022 9:19:03 PM • Quasar Televison... • Answered on Jul 25, 2022
How do u switch the settings on a Quasar TV/combo to the av Jack's from the cable jack it's a older TV that I use sometimes
no model TV told at all.nor year made. 1967 to 2004?????? not sure what you are attempting at all first off there are no more VHF/UHF wide band TV now. its all gone. bye bye. HDTV yes , old analog is gone. buried. this TV is NOT CABLE ready, back in 1967 era,no such thing. make relic TV work needs a video to vhf channel 3/4 converter like old Pong or ATARI games had. yes there are converters. to do video to modulated channel 3/4 but not told at all what is your video choices,?sources. DVD RCA video jacks. cable modems do not have those. I bet you have cable modem or a SAT modem and converting HDTV to analog is wow hard. if not impossible one can record a video sources and convert it using PONG adapter. to old CRT motorola quasar. quasar Company ceased to exist in 2004. ! Beside Uwave ovens. and Motorola 1974 sold its television business to Matsushita Electric, now Panasonic https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2047675.m570.l1313&_nkw=+RF+Modulator+RCA+Input+Channel+3+4+Adapter+Output+&_sacat=0 the above will work ch.3/4 VHF with video sources.
7/24/2022 2:15:46 PM • Quasar Televison... • Answered on Jul 24, 2022
I have a Quasar 50in model number sq5000
Your EEPROM is bad, if you can find one and have soldering skills and the equipment to remove and replace SMD devices that's the cheap way to fix( $15) if not replace the main board, in your case with the sound issue it may make more sense to replace the main as that should correct that isue as well
1/23/2022 2:13:33 AM • Quasar Televison... • Answered on Jan 23, 2022
Quasar model # RC2030Q
Your issue is .................................
2/3/2021 2:32:41 PM • Quasar Televison... • Answered on Feb 03, 2021
I want to get an antenna for my Quasar VV-2000. What is best for this model and will I need a converter box?
you will need both a digital antenna and a converter box. if you can put the antenna on the roof or on a tower. if you had a newer tv all you would have to get is just the antenna
9/6/2018 1:18:33 PM • Quasar Televison... • Answered on Sep 06, 2018
Quasar television radio combo. ANY way to get channels without a buying a converter. It has screw connections that looks like you are to use some type of uhf transformer type thing. I do not have any of those. I have a vcr and some wire. ANY help???
I haven't heard of a radio/tv combo since the demise of vhf tv. A reasonable radio reception could be derived from the vhf tv signal making a usable unit without the bother of an additional aerial. For use with uhf tv the radio would probably need an additional aerial for decent fm radio reception - unless the radio is am only... You don't say how old your combo is or give any details. I think the screw terminals could be intended to be connected to a 300 ohm balanced dipole aerial for radio reception only or to mount a loop aerial for indoor tv reception only, if the tv is intended for uhf analogue reception. If the tv isn't equipped with a standard socket for the usual 75 ohm coaxial type aerial lead it is possible the set manufacturer originally supplied an adaptor to fit to those two screws in order to provide a regular aerial socket. Without a much more detailed description, these are the only comments I am able to make.
4/2/2018 11:57:10 PM • Quasar Televison... • Answered on Apr 02, 2018
My quasar tv keeps blacking out and I can't get back on it
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
7/3/2017 6:41:43 AM • Quasar Televison... • Answered on Jul 03, 2017
I have a Quasar vhs combo don't have remote. Trying to connect dvd player and don't know how to get to the video mode
Without a remote control, you can't select its inputs. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites. http://electro-medical.blogspot.com/ http://homenol.blogspot.com/ http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
4/2/2017 3:11:43 PM • Quasar Televison... • Answered on Apr 02, 2017
Televison & Video Logo
3 questions posted
Top Quasar Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Quasar Televison & Video
Most Popular Question
friend quasar sp 3231 television
  • Televison & Video
