20 Most Recent Panasonic ESLA93k Electric Shaver Questions & Answers
7answers
I'm on my second Panasonic
I've also seen this problem now... In my case re-seating the cartridge helped for a few days, but after that I got continuous flashing status LED. Turns out (after disassembling of the cleaner base) that the cross-shaped arm that checks for cartridge presence activates a micro-switch that is supposed to be open when everything is OK. I seem to have gotten a bit of water in it and therefore now it was recognized as missing all the time. As I have no plan of ever attempting to run the cleaning cycle without cartridge I disconnected the switch and isolated the cable ends - problem solved.
Disassembling of the base wasn't at all complicated when you have removed all the screws. There are three less obvious screws under the rubber feet (just pull the feet straight out), other that that they are all very visible.
3/30/2019 9:22:57 PM • Panasonic... • Answered on Mar 30, 2019
0answers
0answers
Panasonic ES-LV81 electric razor with self cleaning recharger won't go into clean cycle only dry.
If you take the cleaning unit to pieces you will find a tiny microswitch that detects that the cleaning cartridge is in situ. This switch is fed by 2 brown wires. The microswitch is prone to get water on it and then malfunctions. Unless you are adept enough to find a new one and fit it, in my opinion the only way around this problem is to snip one of the brown wires and re-assemble the unit.Effectively this is overriding the units ability to sense that the cleaning cartridge is in position!As long as you remember to NEVER run the unit without the cartridge in situ, the wash and dry cycle should work fine.Best Regards.Ian.
10/25/2013 9:14:28 PM • Panasonic... • Answered on Oct 25, 2013
Problems with automated Cleaning. The charger
Is this a new problem? Or did you just clean it for the first time? A little more info would be appreciated. Thanks!
12/14/2010 8:37:14 PM • Panasonic... • Answered on Dec 14, 2010
I need a charging cord for Panasonic ER203 beard trimmer.
Looks the same
AC Adapter For Panasonic ER2031 ER2051 AC ... - eBay
https://www.ebay.com > itm AC Adapter For Panasonic ER2031 ER2051 AC Rechargeable Beard Hair Trimmer Power. Hover to zoom.
8/19/2022 5:25:26 PM • Panasonic Health... • Answered on Aug 19, 2022
What is the mAh of Panasonic ES 8003 shavers Ni-MH battery?
google Panasonic Shaver Battery + Waterproof Grease ES8003 available on ebay.
1/24/2022 8:12:38 PM • Panasonic Health... • Answered on Jan 24, 2022
I have Panasonic ER 217
poss not makeing contact in recharger seat.
7/17/2021 10:04:22 PM • Panasonic Health... • Answered on Jul 17, 2021
How to replace batterirs in panasonic es2045 epilator?
The batteries were not designed to be replaced. Buy a new one.
12/7/2019 9:36:01 PM • Panasonic Health... • Answered on Dec 07, 2019
Replacing ni-cd battery in panasonic beard trimmer er389
It isn't really a person friendly replaced battery. You will need to solder wires.
8/11/2019 8:39:34 PM • Panasonic Health... • Answered on Aug 11, 2019
5answers
I have a Panasonic ES8109 razor. I need to replace
IF the seal is broken and you want to reseal it. I would use a small bead of silicone.
Or on the link below click on the Find parts for your product next to the gears. Then enter the model #. Then scroll down to WATERPROOF RUBBER SEAL to order a new one.
Good luck and please rate 4 thumbs up for the free answer
3/19/2019 4:51:34 AM • Panasonic Health... • Answered on Mar 19, 2019
What is the value of R3 in Panasonic ER206 trimmer?
buy super vidalista Online is used for Enlarged prostate gland in male, Increased blood pressure in lungs and other conditions. Know about the uses, side effects, price, composition, substitutes, How it works, Lowest Price Online. Super Vidalista Online buy with lowest Price Ever Online Pharmacy. Super Vidalista Reviews.
1/2/2019 8:45:32 AM • Panasonic Health... • Answered on Jan 02, 2019
Where to buy panasonic er 409 parts
Karkhano market peshawar you should go their and their have a big market and wholesale dealers.
12/29/2018 1:03:19 PM • Panasonic Health... • Answered on Dec 29, 2018
Need new head and cutter for Panasonic Es7101s
shaveroutlet.com has this part
12/14/2018 4:15:15 PM • Panasonic Health... • Answered on Dec 14, 2018
Wet/ dry panasonic es2207 razor quit working
If you've had the shaver for a few years or more, the battery is probably dead. Because the batteries are specialized and not available, replacing the unit may be in order.
9/23/2018 3:21:03 PM • Panasonic Health... • Answered on Sep 23, 2018
SERIAL # ON PANASONIC WET/DRY RAZOR
If you are trying to located a serial number, it may be on the box that the razor came in.
2/25/2018 3:40:22 PM • Panasonic Health... • Answered on Feb 25, 2018
Panasonic ESLA93k Electric Shaver Logo
10 questions posted
Top Panasonic Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
 Mikey
Mikey
ADMIN Andrew
ADMIN Andrew
Are you a Panasonic Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Health & Beauty
Most Popular Question
problems automated cleaning charger
  • Health & Beauty
