20 Most Recent Harman Kardon HS 200 Theater System Questions & Answers
Check the capasitors in the power supply. These often have a popped top surface, not flat like normal. These need to be changed. It can be as many as 10-15 bad ones.
Harman Kardon HS... | Answered on Sep 28, 2015
I have the same issue - have you managed to figure out what may have caused this issue and how to remediate it?
Go to radio shack and see if they have then, or Google it.
Harman Kardon HS... | Answered on Feb 23, 2015
Unit is in protection as it has a faulty in prob the PA stage
Harman Kardon HS... | Answered on Jun 26, 2014
hi,
set tv in tv mode
go to audio setup then check the audio output settings. it should be in internal speaker setup,
then only u can hear the audio though ur tv. if it is in amplifier mode then the internal speaker will be off. check it first.
ok
Harman Kardon HS... | Answered on Jan 12, 2011
change the motor disc spindle
Harman Kardon HS... | Answered on Aug 17, 2010
Having looked at the manual to the 354 it says that analog 2 should be used. These will connect directly to the in and out of the equalizer. You will need to connect say a cassette deck to the equalizer if you have one. The out setting of the analog 2 go to in the in of the equalizer. The out of the equalizer to the in of 354.
However if you are listening to a digital sound it will not send that to the equalizer as there is no converter built in.
So you can NOT record the digital sound, using the analog 2 phono sockets.
Harman Kardon... | Answered on Aug 14, 2018
Harman Kardon HS 200 Theater System Logo
21 questions posted
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Harman Kardon Audio Players & Recorders
Most Popular Question
inserendo il dvd dopo alcuni
  • Audio Players & Recorders
