20 Most Recent
Gli Pro XA9900 Amplifier Questions & Answers
Power TransistorsQ17 and Q16 along
Hi kwalsh4,
For this concern, you need to contact
Gli Pro directly since they are the only one who can provide you the schematic diagram for this specific model. If you call them, they will send you one via email. For contact information please visit this
link.
Gil Pro Contact information:2691 West 15th Street
Brooklyn, NY 11224
1-800-GLI-PRO-1
FAX 718-946-4151
Email: [email protected] Hope it helps.
Thank you for using FixYa.
Gli pro bd 1600 turntable
The GLI PRO BD1600 is a turntable, likely a budget model produced by GLI PRO, a brand that produces various audio and DJ equipment. Unfortunately, information on this specific model is scarce and I couldn't find much information on its specifications or features. It's possible that the model may have been discontinued or is only available in limited markets. If you're interested in purchasing a turntable, you may want to consider researching other models that better fit your needs and budget.
Blown fuses
Hi Anonymous. You have a few choices. You can download a PDF of the service manual ,or you can take the cover off and locate the fuse yourself. Chances are it may be more than one fuse blown. Some fuses are located under circuit boards..hard to get to. The service manual should tell you what kind of fuse you need. If you can`t replace the fuse yourself,you can always take it to an authorized service tech.
Need a new belt
Hi, we have belts for all models in stock. Cheers John. Stylus City
Audiosonic CR-06PL not changing time when following manual instructions.
Set Time Hours and Minutes: Press Time/12/24 and Alarm1/ON/OFF buttons at the same time for two seconds and it will start to blink the hour.
Press and hold the button for a fast setting or tap it briefly to increase the setting by one hour. Now set the minutes with time (press and hold) and min.
How do I set the Audiosonic clock? Set current time Press and hold the time button and simultaneously press the hour to set the hours in 24-hour mode .
