20 Most Recent
Troy-Bilt XP 2800 PSI 2.5 GPM Gas Pressure Washer 020488 Questions & Answers
Does not have a choke. how do i start it?
does it have a primer bulb
if so press it several times until you feel a slight resistance
open the throttle up and pull the cord
the primer bulb squirts a set amount of raw fuel directly into the manifold
Troy bilt pressure washer 2800 bought at Lowe's will not spray at full pressure after a minute or two. Loses pressure. Unable to use it.
That could be a number of things. A foreign object keeping a valve from shutting. A faulty shutter valve which needs to be replaced with part number AR42497. The EZ start valve could be not seating properly. And could also be the unloader valve is broken where it seats in the pump. Now if you had good pressure for only a second or two and then stopped pumping water, then I would definitely say that it is the shutter valve. Pump may also need to be taken apart and cleaned if it has deposit build up in it. If it is the shutter valve you could just remove it. You would still have high pressure but you would not be able to use the chemical inlet. To remove the shutter valve you will have to unscrew the water outlet tube. Then use a self tapping screw or a deck screw and put a couple of bites into the small hole you will see inside the pump. Then remove the deck screw and use a large plane screwdriver and unscrew the fitting inside. The fitting will not come out all the way. Reinsert the deck screw just to get into the threads you just made. You may have to use an allen wrench and hold the screw driver slot so as not to accidentally tighten the fitting as you tighten the deck screw. Pull on the deck screw with a pair of pliers and remove what is called the chemical injector. Then behind that is a small spring. You can either use a small pick tool, magnet or low water pressure running through the pump to wash them out. Then there is the jet behind the spring. Kinda looks like a small hollow bullet with two holes in the side and an o-ring at the tip. Replace the water outlet tube without those three parts and see how the pump works. You will have high pressure just not the use of chemicals. If you still have low pressure then you will have to inspect the pump for broken valves or poorly seated valves. Here is the breakdown of the pump in the link.
http://www.arnorthamerica.com/newbreakdowns/Pumps/rmw_3400.pdf The old style of shutter valves were a common problem causing low pressure. If the jet (the part that looks like a bullet) you pull out is perfectly round then you have the old style and will cause problems later on. Replace it with AR42497 . If the jet has flat shaped surfaces then you have the newer style. I'm assuming you made sure the tips and gun were not getting clogged. Good luck.
What are the advantages of using HDPE pond liner sheets for constructing a pond?
Here are the advantages of using HDPE pond liner sheets for constructing a pond:
- Durability and Puncture Resistance: HDPE is a tough material that can withstand wear and tear. It's resistant to punctures from rocks, roots, or other sharp objects that might be present in the soil under your pond. This translates to a long lifespan for your pond liner, minimizing the need for replacements.
- UV Resistance: Unlike some materials that degrade under sunlight, HDPE liners are UV resistant. This means they won't become brittle or break down over time when exposed to the sun, ensuring the liner lasts for many years.
- Chemical Compatibility: HDPE is non-toxic and resistant to many chemicals. This makes it safe for fish and plants in your pond, and it won't leach harmful chemicals into the water if you need to treat the pond with certain substances.
- Suitable for Large Ponds: HDPE liners come in large sheet sizes, making them ideal for constructing bigger ponds. The large sheet size reduces the need for seams, which can be weak points in a liner, and simplifies the installation process for larger ponds.
- Relatively Easy Installation: While professional installation is always recommended, HDPE liners are lighter than some other pond liner options and can be workable for DIY projects. They can be welded together to create a secure seam, and their flexibility allows them to conform to the contours of your pond.
- Cost-Effective in the Long Run: Although the upfront cost of HDPE liners might be higher than some other options, their durability and low maintenance requirements make them a cost-effective choice in the long run. You won't need to replace them as often, and they can help prevent leaks that could damage your landscaping or require repairs.
3/18/2024 7:08:38 PM •
Garden
Answered
10 hours ago
Where can I find a baumr-ag sx45 0.325 chainsaw cog
usually doing a bit of research on google con bring you up a parts list & suppliers. with the make and model number & then type in either service manual or parts list.pdf. of even a schematic can bring you pictures or websites to help. maybe some scrolling through is needed but you should be in the ball park with this one.
3/15/2024 11:12:06 AM •
Garden
Answered
3 days ago
I would like to print out a service and parts manual for a 2015 ck30
Obtaining a service and parts manual for a specific model, such as the 2015 CK30, typically involves contacting the manufacturer or an authorized dealer. In this case, CK30 likely refers to a compact tractor model, and the manufacturer would be KIOTI.
3/9/2024 2:05:09 PM •
Garden
Answered
on Mar 09, 2024
Are the cushions on my outdoor sofa waterproof?
Cushion covers are treated with a water repellant coating. Spilledliquids can be easily wiped off. I would recommend removing andstoring the cushions in a dry place when not in use
3/6/2024 9:46:54 AM •
Garden
Answered
on Mar 06, 2024
