FixYa.com
Tamarack HV1000-R Fan
All Products > Tamarack > Electric Fans
Problems with Tamarack HV1000-R Fan?
Search inside Tamarack HV1000-R Fan Knowledgebase
Troubleshooting and Support
Solved Problems for Tamarack HV1000-R Fan RSS Feed Post a New Problem
I removed the old fan & light. There...
I removed the old fan & light. There are 3 wires coming out of the ceiling - white, black & red. The wires...
1 Solution
I have a 36 inch ceiling fan with four...
I have a 36 inch ceiling fan with four wooden blades. The thing always ran with a little wobble, but after it was taken...
1 Solution
fan problem
whines when turned on. seems to be either a grinding or a off-balance of blade and shaft
1 Solution
Electrical Problem
installed a carriage house 2. Light kit works, fan does not. took apart, investigated... white electrical connector...
1 Solution
snowthrower won't stay running
when priming it leaks gas and hard to start and won't stay running
1 Solution
purchased a hap 726-on 2/7/08 holmes...
3 days later the unit is not working? i've checked to make sure everything is seeded properly, nothing. all light...
1 Solution
Casablanca W32 Fan and Light Switch...
I installed a new W32 wall controller for a Casablanca fan and the Fan and Light switches are reversed. When I swap the...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Tamarack HV1000-R Fan RSS Feed Post a New Problem
converting to variable speed
I would like to convert this fan to operate at variable speeds. Installing a 3 wire variable speed ceiling fan switch...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Speeds1 Speed
FeaturesRemote Control (Included)
Power
Power116 Watt
CFM1,000 CFM
Dimensions
Width22.25 in.
Weight24 lb.
Warranty
Warranty3 Years
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
