20 Most Recent
Dell AX210 2 Speakers Questions & Answers
Studio 1735
Could the source be on another mode? For example, Its on tuner and not on aux or vise versa
My speakers were working fine
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
if you dont have a motherboard disc you will have to download the drivers
I took the plug out of the green outlet to move
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
hope this helps
No sound not working everything is plugged in
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
hope this helps
No sounds coming out from
- Check that it is turned on with correct power supply
- check your sound of OS
- check that you have the audio driver of PC
I have dell ax210 -2
Your speakers don't require any special drivers. All they do is take the analog sound signal from the computer, amplify it and play it for you. If the sound hardware is working, all you need to do is plug in the
speakers. The green signal plug goes into the output jack on the
computer, and you need to connect the USB plug to an open port for
power. Your computer needs driver software for its sound hardware, though, and if you're trying to solve a "no sound" problem, this may be the cause.
You don't give a make and model of your computer or sound card, so I can't give you a specific link. But you can get the drivers from the computer manufacturer's site. If you have a custom-built computer or are using a separate sound card, you'll need to get the sound drivers from the motherboard manufacturer (if it's integrated sound) or sound card manufacturer.
My speakers are making voices and music and any
you will need to locate the volume button at the bottom right hand off desktop and change the volume settings, i cant say exactly witch setting to change because i don't know what software you are using. But something in those settings is causing this.
Any further questions please ask.
Correct? vote would be usefull.#
Thanks.
