20 Most Recent
Liebherr KGK 2833 Comfort Bottom Freezer Refrigerator Questions & Answers
How should I set the temperature. The
Basically the thermostat controlls the freezer temperature which turns the compressor on and off.
The refrigerator section receives cold air from the freezer to cool it down.
So when the freezer is off there may not be enough cold air left for the refrigerator.
Fridges can never give you a perfect temperature every time there will always be a drift one way or another.
Once you reset the temperature the numbers or an led should blink at you to confirm the changes you made
REd light is flashing over
Hi!!Check temp. settings, If temp is too warm the fridge starts beeping and flashing the lights. the most common problems are:
- Ice build up on freezer back wall or evaporator, take a look behind the drawers, it should not have any ice build up.
- Bad Evaporator Fan Motor or dirty Evaporator Coils,
- Defective Door Seal/Gasket
- Bad Defrost Heater
- Defective Thermostat
- Bad Compressor or Freon Gas low
Unplug power cord from wall outlet for 5 min., plug it back up and check that the compressor and condenser fan on the back are working, open the freezer and check that the evaporator fan is working.
Good Luck! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Liebherr freezer working, refrigerator doesn't
Take the cover off the fridge fan and put a flash light in there and a camera set to record. close the door for a couple of minutes and then look at the footage to see if the fan is running. The circulation fan should run all the time.
4/5/2023 4:16:50 AM •
Liebherr...
Answered
on Apr 05, 2023
LIEBHERR CBNes 39560 Fridge - ice in the drainage trough on the back?
Question edited for correct spelling of the maker.
Question moved to maker category.
Check the temperature of the fridge with a digital thermometer. I should be 5' centigrade. It may be set too cold and freezing condensation running on the rear wall. Also make sure the circulation fan is working. It looks like it is the round disc at the top rear.
Push a flexible net curtain wire down the drain until it appears above the compressor pan.
You can also try cleaning the drainage trough, dry it and spray it with dry silicone spray or even WD40 if you don't mind the smell. That will stop water sticking.
https://mediamarkt.pl/agd/lodowka-liebherr-cbnes-39560
3/29/2023 5:02:00 PM •
Liebherr...
Answered
on Mar 29, 2023
