20 Most Recent Curtis-Mathis CM25011 25" TV Questions & Answers
If it is a tubed TV, repair the frame stage.
Curtis-Mathis... | Answered on Oct 01, 2017
My MR701 Telefunken TV set does not want to switch on with its remote control.When I switch of the plus nad then on again. It switches on and a sign with the key and wording MENU appears after few seconds it switches off again.Some times it does swtch on with a universal remote. The red light where the sensor is keeps on lickering when its on standby.Under normal circumstances it stays red without flickering when the TV set is
on standby. Please help.
Curtis-Mathis... | Answered on Apr 19, 2013
Check the power supply regulator board. Replace it if necessary.
Curtis-Mathis... | Answered on May 07, 2012
100 Centimetres in one metre
Curtis-Mathis... | Answered on Apr 11, 2011
try useing menu thru the tv itself
Curtis-Mathis... | Answered on Mar 06, 2011
It sounds like the captions for the hearing impaired is active, get remote and select menu, scroll down to captions, right arrow 1,2,3,4,off, make sure cursor is over off and press enter on your remote and should restore normal function to the set, some remotes have the caption button that is separate from the menu.
Curtis-Mathis... | Answered on Mar 05, 2011
Hello
Thee digit universal remote code for Curtis Mathis are:-
000/ 001/ 004/ 009/ 015/ 031/ 049/ 105/ 109
Four digit universal remote codes for Curtis Mathis are:-
0031 0105 0130
0004 0009 0000 0049
0109 0358 0001 0015
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Curtis-Mathis... | Answered on Jan 10, 2011
more than likely your picture tube is burned out. not worth replacing can buy a new one cheaper
Curtis-Mathis... | Answered on Dec 25, 2010
need code for tv. lost booklet and cnt emember code
Curtis-Mathis... | Answered on Aug 03, 2010
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Curtis-Mathis... | Answered on Apr 15, 2010
The lowest possible common factor is 15.Answer is :19/15
Curtis-Mathis... | Answered on Apr 01, 2010
Try these codes for your remote and TV. The are the Zenith codes for a Curtis Mathes TV.
CURTIS MATHES.....002 103
............................. 112 502 506
..................... 512 601 701 704
These should work.
Regards,
Mike
Curtis-Mathis... | Answered on May 09, 2009
-3x+7y=-1 and -2x+5y=0
Curtis-Mathis... | Answered on Feb 22, 2009
X=25-y
4(25-y) + 5y=56
100-4y+5y=56
100+y=56
y= -44
x=25+44=69
x=69 y= -44
Curtis-Mathis... | Answered on Aug 22, 2008
hi this is common problem you will find the bulb needs replacing if you still have sound then it will be worth getting done
Curtis-Mathis... | Answered on Apr 10, 2008
Sometimes if the screen was affected by magnets it will fade. you could try placing magnets around the screen and moving them around, BEWARE you could make it worse. If it dosent fade youve had it........Sorry
Curtis-Mathis... | Answered on Mar 23, 2008
Your electron gun is failing. Throw it away!!!!!!!!
The contrast setting controls the relation between the light and black areas of the screen. If the light areas are too bright and are losing details, press the CVOL button; if the picture is gray and lacks contrast, press the VOLB button
The brightness setting controls the overall amount of light in the picture. If the picture is too bright, press the CVOL button; if the picture is too dark, press the VOL B button
The color setting controls the intensity of color.
Curtis Mathes CM19102 Owner Manual Returning To The Factory Settings...
Curtis-Mathis... | Answered on Apr 09, 2016
Curtis-Mathis CM25011 25" TV Logo
Popular Tags
25 questions posted
Popular Products
Top Curtis-Mathis Televison & Video Experts
matt martin
matt martin
Vitally Alcher
Are you a Curtis-Mathis Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Curtis-Mathis Televison & Video
Most Popular Question
curtis mathis 25 tv 5 years old
  • Televison & Video
