20 Most Recent Samsung SHS223B DVD±RW Burner Questions & Answers
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd drive including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Samsung SHS223B... | Answered on May 12, 2011
im not sure exactly what you mean???
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
hope this helps
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Samsung SHS223B... | Answered on Jan 10, 2011
If you have CD-DVD burning software uninstall it and restart the computer.Open this link and click on run now http://support.microsoft.com/kb/929461
Restart computer again and check
Samsung SHS223B... | Answered on Jul 29, 2010
open the sh893m than get the hdd and reformat it when done put it back in the sh893m make sure u have a dvd+r with the latetst firmware on it so that the software can be rewritten
Samsung SH... | Answered on Jul 22, 2014
Hey,
Don't worry about this i also have face the similar type of problem with my samsung device than i call on 1-877-778-89-69 expert give me better support and made me smile.
http://resolit.us/Samsung-Support.html
Samsung... | Answered 4 hours ago
How did they take your licence exactly, did you allow them remote access to your device please give us more info on your issue so we can help
Samsung... | Answered 2 days ago
****WARNING**** THIS POST IS SPAM AND ALL THAT LOOK LIKE IT ARE SPAM ALSO..NEVER CALL ANY PHONE NUMBERS IN A FIXYA POST. YOUR MONEY AND CREDIT INFORMATION IS IN DANGER IF YOU DO...SO DONT OK??? HAVE A NICE DAY.. YOUR FIXYA SPAM HAMMER....:)...mmmmjujh
Samsung... | Answered on Sep 12, 2019
Just bought a Samsung GT-C3303K mobile phone. When connected to my PC it says I need to install the correct driver. How can I install this software??
if you are using your phone search themes for samsung gt-c330. go here: http://www.pinoyden.com.ph/index.php?topic=70509.0
or http://www.sharewareconnection.com/software.php?list=Samsung+Champ+Gt+C3303+Themes
Samsung... | Answered on Sep 10, 2019
Hi
You need a USB data cable and samsung PC suite software to be able to connect with your computer. Once you install the samsung PC suite, use the USB cable to connect or transfer data.
Samsung... | Answered on Sep 05, 2019
this is a ver y good sight and make sure you have your data cables ready all drivers you should need will be here
http://ptf.com/samsung/samsung+corby+gts+3653+data+cable+drivers+connectivity+to+pc/
Erofflps.txt is not so much usable file, Next time when you will get this message, do not close this message, just open the task manager and see the process after that disable it from the startup (by typing the command msconfig in run box)
Samsung... | Answered on Aug 30, 2019
if it is still under warranty contact the store that you bought it from otherwise have it service. good luck.
Samsung... | Answered on Aug 27, 2019
You have 2 Relic HDD (PATA -IDE ATA-133) they are junk.
we learn it is a DVR posted to computers so is off topic here, but not that DRIVE>
Sounds like the person that repaired your phone used spare parts from a stolen phone and that used part still has the original owner's Samsung Account ID protecting it.
Should be automatically detected by your computer system.
Samsung... | Answered on Aug 19, 2019
Samsung SHS223B DVD±RW Burner Logo
4 questions posted
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
SH Samsung
  • SH Samsung
Most Popular Question
don 39 t record
  • Computers & Internet
