20 Most Recent
Dell Studio XPS 1645 Laptop Questions & Answers
Eject dvd disc
Look for a very small hole in dvd door, use a small object like a paper clip and push it into the hole. The door will open.
Laptop display has vertical bars
It is unfortunate that the LCD screen has vertical bars on it. Please send me a picture of the LCD screen via email to
[email protected]. You may also try performing an LCD BIST using the below link:
http://dell.to/1irqbYp
Also try connecting a known good external monitor and check if that helps.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Acer aspire 5542-1615
No,
Please scan that other computer with free
version of superantispyware:
http://www.superantispyware.com/
Can't open a web site.
Hrm ... run a program called malwarebytes. It does a way better job in finding an potential virus/malware on your system. There is probably a registry that is preventing you from browsing correctly. Run malwarebytes and hopefully it will alleviate your issue
Locked Dell computer operating in Windows 7
Lost Windows password:
- Login as Administrator. Try with no password (load safe mode if you don't see Administrator). Press F8 during boot to access Safe Mode.
- Login as other user (if other user is available) and manage users. Must be an administrator.
- Reformat computer.
- Use 3rd party software to remove password. Like http://www.top-password.com/reset-windows-password.html
Problem with a Dell Keyboard
- Click Start , type intl.cpl in the Start Search box, and then press ENTER.
- On the Keyboards and Language tab, click Change keyboards.
- Click Add.
- Expand the language that you want. For example, English (United States).
- Expand Keyboard list, select the United States-International check box, and then click OK.
- In the Default input language list, click Language name - United States-International (where Language name is the language that you selected in step 4), and then click OK two times.
- In the Regional and Language Options dialog box, click OK.
Notice that the Language bar appears on the taskbar. When
you position the mouse pointer over it, a ToolTip appears that
describes the active keyboard layout.
- Click the Language bar, and then click United States-International on the shortcut menu that appears.
The United States-International keyboard layout is selected.
Laptop screen problem
click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settingsalways click APPLY after making any changes
windows 7
Open Personalization by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization.
Click Window Color and Appearance.
Under Window Color and Appearance, click the color you want, and then click OK.
Note
If you see the Appearance Settings dialog box instead of the Window Color and Appearance
window, the theme might not be set to Windows Vista, the color scheme might not be set to Windows Aero, or the computer might not meet the minimum hardware requirements for running Windows Aero. For more information, see Troubleshoot problems with Windows Aero.
hope this helps
How to change the keyboard
You have to remove the palm rest ( the top part that has the keyboard and touch pad) to access the 13 screws securing the keyboard and shield which are underneath the palm rest. This involves removing the bottom access cover, rear caps, remove ten screws that are marked with a small P on base of computer. Remove two screws that are marked with a K. Remove two flat-head screws in the battery compartment. Then flip the system over. Remove the two screws at the top of the palm rest. Pry the palm rest loose with your fingertips, starting at one edge. Flip open the latch on the keyboard ribbon cable connector, and remove the cable. Lift the latch on the touchpad ribbon cable connector, and remove the cable. Remove the palm rest.
I can not reboot my Dell Studio XPS 1645 running
Sounds like you've tried everything except a complete reinstall. If there is information you need off that computer the hard drive will need to be taken out and plugged into another PC as a second hard drive then all can be copied. Then try a complete reinstall and good luck with that. If any problems doing a reinstall i would look at the ram. Cheers from Scott and plz vote
"operation system not fount" after pressing the start button
Turn it off. Symptoms suggest hard drive failure. Use of s taking a physical battering. This may damage data beyond recovery. The drive Take it to a shop. Your other choice: Oddly, freezing the hard drive sometimess temporaily fixes the drive long enough to recover data. Replacement of the hard drive is the likely fix. Unless you want to try to freeze the HD and copy data off of it quickly, only a shop specializing in data recovery might recover such. Hopefully youhave backed up data to another drive. You might want to consider a new laptop, after you eye the possible cost of repair and/or data recovery.
Studio XPS 9100 - I cannot access the internet from this computer consistently and shutting down takes 25 minutes
Always include the version of Windows in your posts.
Could have been a RAM problem if you got 4 beeps and you seem to have resolved that by reseating the modules. But the RAM error may have caused some corruption to a file on the hard drive.
Assuming the diagnostics pass, you can reboot and press F8 before Windows starts to load. Select Last Known Good. If that gets you to the desktop without errors, shut down normally and reboot normally, and you should be good to go.
You may also want to run chkdsk on the hard drive:
Click: Start>run
Type in: chkdsk C:
Click OK
Accept the offer to run chkdsk at next boot and then reboot. chkdsk will run before Windows loads. It may take a long time, depending on size of your hard drive, so be patient.
Rapid beeping
Can you specify WHEN and perhaps what was on the screen? What were you doing when the problem started?
Can I charge my PP39L laptop with a USB cable?
the only thing to be aware of is the voltage cannot exceed that required for the laptop . for example if the solar panel puts out 12 volts you will need an adaptor before the usb connection to reduce the power to the voltage for the laptop
