20 Most Recent Visual Land VNet VL760 Netbook Questions & Answers
My visual land turn white when I turn on anapp
Try to turn back your old 4 GB SSD card
9/4/2014 10:39:47 PM • Visual Land VNet... • Answered on Sep 04, 2014
Is there a substitute AC adapter charger I can use for my V-Net 760 notebook
Ebay has tons of them. Log into ebay and type in AC charger for V-Net 760 notebook and several options should appear. I have bought several for my laptop computers through ebay. BestBuy also sells a generic charger made by Rocketfish that will come with a plethora of adapter ends to match your computer.
7/3/2014 4:10:55 AM • Visual Land VNet... • Answered on Jul 03, 2014
3answers
WENT I STAR MY NET
Try to check your disk here is a link to explain using your installation windows disk
If you don't have a disk you can probably find one one the net or borrow one..
http://technet.microsoft.com/en-us/library/bb491051.aspx
1/14/2014 2:34:38 PM • Visual Land VNet... • Answered on Jan 14, 2014
How do i change the language on the netbook?
By reflashing firmware with other languages. Only English or Chinese are available.
1/14/2014 2:32:37 PM • Visual Land VNet... • Answered on Jan 14, 2014
2answers
How to dissamble
DONT. Take to repair shop.
1/14/2014 2:31:47 PM • Visual Land VNet... • Answered on Jan 14, 2014
How to dissamble v net notebook
You will need to resolder the port. It is easy to disassemble it. Just unscrew all screws in bottom and remove keyboard then it is straight forward. If you don't have soldering skills take it to repair shop.
1/14/2014 2:31:22 PM • Visual Land VNet... • Answered on Jan 14, 2014
2answers
Can't turn on my VL760 netbook. It just "initializes."
As you mentioned the problem is above your control and it is hardware related issue, kindly go to the authorized service center, as it is a new net book don't do anything to you may loose your warranty.
Thank you.
1/14/2014 2:29:27 PM • Visual Land VNet... • Answered on Jan 14, 2014
Have visual land net vl760 is there anyway to
install android 1.5 on it!~! it will be usefull instead of being a paper weight!
1/14/2014 2:27:56 PM • Visual Land VNet... • Answered on Jan 14, 2014
2answers
Battery won't charge, ran low
Remove the main battery and clean the metal contacts with a toothbrush, this way any dirt will be removed and maybe the computer will have no more issues.
1/14/2014 2:17:38 PM • Visual Land VNet... • Answered on Jan 14, 2014
I have a v.net mini notbook vl 760 i make the usb flash is not work in my computer then i open my computre and i no't found it how i can do help me plz
Some flashdisks do not work it is known issue. Also use only back USB port.
1/14/2014 2:06:50 PM • Visual Land VNet... • Answered on Jan 14, 2014
2answers
How can i wipe my
Some solutions:
(#). [Suggestion] -RATING-
1. Replace your hard drive -** - 2. Go to my computer and right click your drive and select format -**** - 3. Ask an expert to wipe it for you -*****-
1/14/2014 2:05:53 PM • Visual Land VNet... • Answered on Jan 14, 2014
How to set up WiFi Connection
Turn on your computer and locate the Wi-Fi icon. This could be located on the upper row on a laptop it will have the radiation look ((())) Make sure its pressed on. Usually a wifi enabled phone, computer, or whatever device, will recognize if there is wifi access near you. If not you may need to turn on the wifi on those devices. Usually those setting can be found in menus like Network Settings. Once it recognizes the network you will need the password if it is required. Just enter that in and you are set. Where you enter the password is usually in the same menu in which you turned on your wifi enabled device. if still no connection Power on the laptop computer and wait for the operating system to boot. Right-click the wireless Internet icon in the lower right corner of the desktop. This brings up a new pull-down menu. Select "View Available Wireless Networks." This brings up a selection of different possible Internet connections that are in range of the computer. Select the wireless Internet connection you want to use. If a password is required, you need to type it in now. Wait for the laptop to connect to the Internet. In a moment the computer is going to state it has successfully connected to the Internet. Click Start, Run type in cmd and click Ok to bring up a command prompt. Type ipconfig /all and press enter and see if it gives you an IP address similar to 192.168.1.100. Check your wireless connection properties under My Network Places. Right click the wireless connection icon and choose properties. From there make sure Internet Protocol {TCP/IP} is listed, highlight it and click properties. Make sure Obtain an IP address automatically is checked and Obtain DNS server address automatically is checked. Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabled if still no joy Let's first try to start the wireless service i.e. WLAN AutoConfig service manually. To do this, login to the computer as an administrator. 1. Click Start, type services.msc and hit enter. 2. Locate WLAN AutoConfig service, double click on it to open its properties window. 3. Under General tab, change the Startup type to Automatic and click Start button. 4. Click Apply and then ok. For more information about the wireless settings, check this link: http://technet.microsoft.com/en-us/library/bb878035.aspx
2/11/2013 6:55:22 AM • Visual Land VNet... • Answered on Feb 11, 2013
Im have a hard time geyying on the net
You will have to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled. Make sure your antivirus program is not blocking the internet connection. If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc Click start type cmd press enter you will be in DOS mode type in ipconfig press enter you will see all o fyour internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138 Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"imake sure its enabledPci device arrows key scroll to nstalled. Hope this helps.
1/17/2013 12:24:19 AM • Visual Land VNet... • Answered on Jan 17, 2013
How do i make it run faster.
This should help a bit:Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.Download, Install and Run Malwarebytes Anti-Malware:http://majorgeeks.com/download.php?det=5756When Installing choose the non-pro version.Download, Unzip, Install and Run TDSSKiller:http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.htmlDownload, Install and Run Super Anti-Spyware:http://majorgeeks.com/SUPERAntiSpyware_d5116.htmlIf you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.htmlMake sure to select ALL of the "threat categories" when you install or configure Avira...You should be in pretty good shape if you run and install all of these programs.
8/18/2012 12:20:32 PM • Visual Land VNet... • Answered on Aug 18, 2012
Went I hit power button only the three light on
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
9/26/2011 8:35:09 PM • Visual Land VNet... • Answered on Sep 26, 2011
Lost my ac adapter/where can
you can shop at your local computer store or online ;O
8/23/2011 10:46:49 PM • Visual Land VNet... • Answered on Aug 23, 2011
What is the inital Windows
The password is: ztk
This is only used when bios or software is changing.
http://www.visual-land.com/vl760_black.html
User manual! :)
7/2/2011 2:24:23 AM • Visual Land VNet... • Answered on Jul 02, 2011
Visual Land VNet VL760 Netbook Logo
Popular Tags
63 questions posted
Top Visual Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Visual Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Visual Computers & Internet
Most Popular Question
went star net
  • Computers & Internet
