20 Most Recent Gateway NV5378u Notebook Questions & Answers
you did this wrong.
step 1 is run full HDD tests, smart test too.
we use linux demo disk,
NO OS in the world loads to a bad or weak HDD. never !!!
http://www.pcdied.com/linux.html
Gateway NV5378u... | Answered on Sep 08, 2018
sounds like you have either a bad module or it is not the right kind , if you have ddr2 memory stick and you have added a ddr3 it will not work or you have exceeded you systems memory capability it will not work .
Gateway NV5378u... | Answered on Jun 15, 2014
Check it is not muted by right clicking on the loudspeaker icon and look at recording devices.
Gateway NV5378u... | Answered on May 29, 2014
Good day
Look at the top of your skype program where you see, Skype, Contacts, Conversation and so forth, look for and click on "Tools" after you click on Tools a little window will pop down and then click on "Options", then look to the left and click on "Audio Settings".
The window to the right will change at the top you will see "Microphone" click on the drop down box to the right of it and a list of all your microphones will come up click on each and test until you find the one that you are currently using.
I have attached pictures below to assist you.
Hi Eric,
Sometime we can find solution from the very basic. How about to adjust brightness of your screen by using keypad?
Gateway NV5378u... | Answered on May 04, 2014
try restore using factory discs or bootable drive. You made a bootable drive right? Right? LOL good luck
Gateway NV5378u... | Answered on Mar 12, 2014
if you look where the hinge is on the right side , the power button is in the middle of the hinge on the outside , push it in .
Gateway NV5378u... | Answered on Mar 10, 2014
1. Charge the battery for 2 hours,
2. Press the power button.
If the laptop does not start, you can do this:
Please use the VGA port (VGA external monitor), also please do these:
1. Unplug the AC adapter,
2. Remove the battery,
3. Remove the hard drive,
4. Press the power button and hold it for 15 seconds,
5. Plug in the AC adapter,
Restart the laptop.
If the problem persist,
Note: Do not insert the battery, and do not install the hard drive.
2. Reseat the memory (remove it and reinstall it),
3. Plug in the AC adapter,
Restart the laptop.
If those actions do not solve the problem, then your GPU/motherboard is dying.
Gateway NV5378u... | Answered on Mar 09, 2014
I had the same problem , turned out the vidieo chip was burned out had to have it replaced cost me 115.00 did a great job . but now my cd player does not work .
Gateway NV5378u... | Answered on Feb 25, 2014
If you purchase a new hard drive and install an OS, you can then, with a usb hd adapter, copy your data back over.
Gateway NV5378u... | Answered on Dec 25, 2013
I had the same problem. Leave your laptop on the charger until the light turn blue. Then turn it on to see if it woks. Other is to switch your roms around.
Gateway NV5378u... | Answered on Jun 01, 2013
If your sound doesn't work you need to go to you webcam and switch the brand by open your webcam and click settings click recording and switch it. that's if when you record you cant here yourself. If you cant open your webcam go to start and start typing webcam and it will pop up! Hope it helped!!!!
Gateway NV5378u... | Answered on Apr 21, 2013
Can you be more specific? Repair what?
Gateway NV5378u... | Answered on Apr 16, 2013
Check device manager see if driver is showing for cd/dvd
If you have a recovery partition on the laptop You can reinstall your drivers and software using your recovery option.
Recovery should be in START/ALL PROGRAMS/SYSTEM RECOVERY (you may need to click Gateway Utilities first).
Then select application& driver recovery
.Or you can download from gateway http://gateway.com/worldwide/ select country then supporrt then drivers download.
Gateway NV5378u... | Answered on Apr 14, 2013
Make sure it is not accidently set to display on an external monitor only by using the following keyboard hot-key:
Hold down the 'Fn' (function) key and click the 'F4' key.
If the screen still appears dead you will want to check if the PC is still under warranty and send it back to the manufacturer for replacement. If not, a nearby PC repair shop should be able to replace the screen.
Gateway NV5378u... | Answered on Feb 13, 2013
Gateway NV5378u Notebook Logo
98 questions posted
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
nv Gateway
  • nv Gateway
Most Popular Question
screen wont turn
  • Computers & Internet
