20 Most Recent Toshiba Satellite L505DES5025 Notebook Questions & Answers
If you have visited the Toshiba website and downloaded and installed the latest drivers from there, then I would suggest that the on board Audio controller is defective and should be replaced. Check your guarantee and see if it can be returned to dealer/maker for repair.
Toshiba... | Answered on Dec 16, 2012
May be it would be registry error It sometimes when the extra and invalid entries of Windows registry make it heavy which cause situations like PC crashes, Blue screen of deaths, PC freezing etc. You can try Recoveryfix for Registry Cleaner Software. It completely scans the system registry repair errors thus making the Windows registry error free.
Check here http://www.recoveryfix.com/registry-repair-software.html for more information
Toshiba... | Answered on Oct 16, 2012
Why does it not work? What is the problem with it?
Is the webcam driver installed in the Device Manager under Imaging Device? Click Start/Control Panel then look for System or System and Performance. Open it and look for the Device Manager. It might be under hardware depending on your operating system. Once you have the Device Manager open look for Imaging Device. If you see it click the + sign next to Imaging Device to expand it to see the webcam. Make sure it says it is working properly.
If you don't see it under Imaging Device then you need to go to the manufacturers website and download the webcam drivers.
Get online and got to www.google.com In the google search box type: "Acer Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the Webcam drivers.
Maybe it is installed but you don't know how to start the webcam. There are not buttons or switches to make it start. It is driven by the application software program.
You have to open the webcam software to activate or start the webcam. There is no button to push or switch to turn on. The webcam software is somewhere in the program list. Click Start/Programs then search for any reference to webcam or camera. Sometimes the webcam might be inside one of the manufacturers folders in the program list so search the folders for it. Some manufacturers have something like Entertainment Experience that will open and show all the entertainment devices such as the dvd drive, webcam, media player, etc. if you see it click it to launch it then click on the webcam or camera icon.
Try using ManyCam
You can always download Manycam and install it. Go to www.google.com and in the search box type: "download.cnet.com" (without the quotes). Click on the link to go to the site. When the site opens look down on the left and you will see a gray area that says Find Software. Type "Manycam" (without the quotes) in the white search area then hit the search mirror. When it brings back your results look for the one that says ManyCam Virtual Webcam. Down load it and install it. Make sure you remove the check box on any junky programs it would like to install. You only want to install ManyCam, no additions whatsoever during the install. ManyCam is totally FREE and easy to use, and you will always know where your webcam software is.
Toshiba... | Answered on May 04, 2012
Here is a link from the manufacture's website: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2520792&rpn=PSLV6U&modelFilter=L505D-ES5025&selCategory=2756709&selFamily=1073768663
Just select the Operating System -in your case Windows XP and than download all the drivers you need.
If you need further assistance, or have further questions please leave a comment. Cheers
Toshiba... | Answered on Oct 25, 2010
You need to redownload the iTunes. to do that, go to www.filehippo.com and search for itunes, click on itunes and it will open another page, on the right side you will see there download. just click on it and it will download to your computer. Remember the location where you will save the installer, coz you're gonna be using it.
open the iTunes installer from the folder where you saved it. just run it and follow the steps to instal. basically you will just click next and next to install it. it's simple to install
hope that helps. please let me know if you will have a hard time installing it.
Toshiba... | Answered on Sep 15, 2010
for a boot what? bootfile? Well the bootfile is either corrupt in your HDD or your trying to change the operating system with a bad CD that is missing the bootfile. Last possibilty is you have a bad hard drive. I am just guessing because you didnt say what u were doing when it happened and all it says is missing boot****
Toshiba... | Answered on Aug 16, 2010
> try to go to the BIOS,turn off pc then turn it back on then keep on tapping F2,if there is still no display,try to go to safe mode by doing the same thing but instead of F2,keep on tapping F8,if still no display,possible LCD problem or hardware problem
Toshiba... | Answered on Jun 18, 2010
If the screen is physically broken (cracked) it's usually NOT covered under the warranty.
You can check your coverage HERE.
Toshiba... | Answered on May 25, 2010
toshiba satellite error 0xc000021a
Blue screen
Toshiba... | Answered on Jun 21, 2019
Do you have a wifi card in the computer? It is a hardware part that you need so that the computer can connect to the wifi. If you have that but can't find it in the operating system. I suggest that you either install or update the driver for it.
You can use RadarSync to scan your computer for the available updates of your wifi driver. Make sure that you connect to the internet first using your ethernet so that it will detect the available driver updates somewhere in the databases of the manufacturer.
David
http://goo.gl/CxsY9u
Toshiba... | Answered on May 22, 2019
go to your browser proxy setting and make the proxy automatic
Toshiba... | Answered on May 21, 2019
check the power ic of the laptop with laptop technicians
use VLC it plays everything it even has extensions like subtitle downloader. VideoLAN Official page for VLC media player the Open Source video framework
Toshiba... | Answered on Apr 29, 2019
Take another video and don't drop your gear. The mishap obviously ruined the original.
Toshiba... | Answered on Apr 02, 2019
Remove the battery and see if it starts up fine, if not then try the following:
1. Unplug your charger cord.
2. Remove the battery.
3. Press and hold the "Power" button for 30 seconds or longer
4. Now plug back in the power/charger cord.
5. Now put the battery back in.
6. See if it starts up now, laptops often get stuck in hibernate mode.
Toshiba... | Answered on Nov 13, 2018
Toshiba Satellite L505DES5025 Notebook Logo
18 questions posted
Top Toshiba Computers & Internet Experts
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
need driver
  • Computers & Internet
