20 Most Recent
Samsung ML 2525 BW laser Printer Questions & Answers
My samsung ML2525w wont print
Take any paper out of the paper feeder and get a plastic ruler the softer the better lift the top of the printer up so you can see where the print cartridges are now push the ruler down through the paper feed roller be careful because you could break the rollers go from left to right right to left twice and check for any debris once you have done this unplug the printer for about 20 seconds then plug back in and let it reset then try copying or printing a doc and see how you go!
I own a ML-2525/XAA and
Per your user manual, here is a list of all the LED status':
Jam ()
Orange
On
A paper jam has occurred. (See Clearing paper jams.)
Online/Error ()
Off
Green
On
Blinking
When the LED slowly bilnks, the machine is receiving data from the computer.
When the LED rapidly blinks, the machine is printing data.
Red
On
The cover is opened. Close the cover.
There is no paper in the tray. Load paper in the tray.
The machine has stopped due to a major error.
Your system has some problems. If this problem occurs, contact your service representative.
A toner cartridge has almost reached its estimated cartridge life[a]. It is recommended to replace the toner cartridge. (SeeReplacing the toner cartridge.)
Blinking
A minor error has occurred and the machine is waiting for the error to be cleared. When the problem is cleared, the machine resumes.
Small amount of toner is left in the cartridge. The estimated cartridge life[a] of toner is close. Prepare a new cartridge for replacement. You may temporarily increase the printing quality by redistributing the toner. (See Redistributing toner.)
I have a Samsung ML-2525
I guess it FixYa didn't accept my (very long, but totally correct) solution that I took the time to type. Because I refused to "sign in".Here's the short version. Load Paper. The same thing happened to me. I replaced the toner cartridge with a new one (because of a FLASHING red light for several weeks) after the red light went to STEADY red. But it still would not print. The paper was "out". When I'd refilled the paper-tray, it printed fine. I had just ASSUMED that the steady-red light meant toner was finally OUT. WRONG! That steady-red light had nothing-to-do with toner; it meant "you're out-of-paper". Don't get confused like I did. Refill the paper-tray. Then take that expensive NEW toner cartridge OUT, and put the OLD toner cartridge back in. And keep using the "dregs" of the toner out of the old cartridge for several more weeks. And DON'T get confused by the paper-is-out condition making that red light STEADY.
Hello! I have Samsung ML-3470N. After replacing
The only problem is the cartridge electronic chip (can't recognize by the printer) Change or reset the chip. I sell this kind of cartridge in my country, but i don't have problem with it.
Squeaking noise while printing.
Dear
It might have the lubricants dried up, Pl. lubricate the gear assy. with silicone grease, the fusser assy. moving parts. Before it check the cart. by replacing another.
Thanks.
Reset ml 2526
hi,your printer cartridge is replae or replace cartridge chip
Blank paper out-put
Most likely you're out of ink, or there is an issue with ink cartridges. Have you checked them?
