There is no indication of power, and no operation. I've checked for the obvious things such as line...
(More)
There is no indication of power, and no operation. I've checked for the obvious things such as line and pcb fuses, and broken wires, but have only found this possibly deffective resistor. I cannot determine the value of this 0.5W resistor due to discolouration from overheating. It looks like 4.7k, but measures close to 48K, making me think it should be a 47k. Can you advise what it should be as it is worth replacing to see if that fixes the fault. If not, we'll ditch it. Regards, Phil Jolliff, Flann Microwave Ltd.
i need a wiring diagram for a fellows sb95c. apart from it being wired reverse polarity, presumably...
(More)
i need a wiring diagram for a fellows sb95c. apart from it being wired reverse polarity, presumably from the factory, it appears that all the 4 cables going to the motor are live, which would indicate to me that there is a broken neutral (return wire) somewhere in the printed circuit board. there is also a single pole relay that does not pull in, but i think that could be related. any ideas?
Full service mobile shredder repair service to inc... Read More
Full service mobile shredder repair service to include mobile shredder and collection trucks as well as stationary shredders 5-200hp.
Call 877-4FIXSHRED
Authorized Service Center or Allegheny, Ame... Read More
Authorized Service Center or Allegheny, Amerishred, Shred-Tech, Weima, Balemaster, Maren,all makes of mobile and staionary shredders, balers, equipment repaired. Hard to find parts machined, Mobile Service 5 state area.
PRINTER SERVICE USA provides factory-authorized ser... Read More
PRINTER SERVICE USA provides factory-authorized service providers for all types of office equipment and trouble shoot and repair faster and more economically than anyone else in the industry. Your equipment will be repaired to 100% specifications.
So many choices, so little time?
PC REPAIR can hel... Read More
PC REPAIR can help you determine the best type of PC to fit your needs and budget, and provide the best sources for acquiring it. PC REPAIR can even procure or build the system for you if appropriate (as in the case of Custom/High-performance PCs).
Our commitment to client satisfaction extends acr... Read More
Our commitment to client satisfaction extends across the nation! Regardless of your location, a technician is available through our network of authorized dealers/repair centers to handle your technical needs. You can reach our PL/HQ at 212-633-6807 and our staff will dispatch a service technician.
