FixYa.com
Fellowes Powershred 420 Shredder
All Products > Fellowes > Shredders
Problems with Fellowes Powershred 420 Shredder?
Search inside Fellowes Powershred 420 Shredder Knowledgebase
Troubleshooting and Support
Solved Problems for Fellowes Powershred 420 Shredder RSS Feed Post a New Problem
Powershred 380-c
Shredder keeps stopping with the red trash symbol showing - which normally appears if bag is full or shredder is jammed....
2 Solutions
Fellowes powershred 320
Works fine in reverse but won't go forward, tries to then stops. Shear pins in place all gears working, lights on. Any...
1 Solution
shredder problems
Our Fellowes 420 Powershredder won't shred.  The red light stays on even after I clean the top inside of the...
1 Solution
Power switch problem
Power switch LED's will go to green and red halting all shredding capabilities. We ensure that the door is closed, turn...
1 Solution
Ativa DQ 120dDoesn't run in auto
The shredder runs like a charm in reverse, but not in auto. Wife put it in reverse the other day and returned the switch...
1 Solution
something is jammed
I guess i put in too many pages at one time because my DQ120D Active shredder is jammed. i was able to pull out all of...
1 Solution
shredder
How do you fix a jammed shredder?
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Max Sheet Capacity20 · 28
Speed40 ft./min. · 32 ft./min.
Cut StyleCross-Cut · Strip-Cut
Throat Size12 in.
Shred Size0.16 x 1.25 in. · 0.21 in.
Other Features
Shredding OperationAutomatic
Integrated WasteWith Integrated Waste
Overload ProtectionWith Overload Protection
Full Bag IndicatorWith Full Bag Indicator
Accepts StaplesAccepts Staples
Dimensions
Depth16.5 in.
Height35.25 in.
Width19.75 in.
Supported Models
Cross-Cut, Strip-Cut
Fellowes Contact Information
Main support number800-955-0959
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
