I've cleaned all of the parts and my heater still won't remain on. It will light initially and then...
(More)
I've cleaned all of the parts and my heater still won't remain on. It will light initially and then within 30 seconds it shuts off any ideas?
have a problem with a laars boiler the pilot keeps going out. the thermostats only work on max as...
(More)
have a problem with a laars boiler the pilot keeps going out. the thermostats only work on max as well. have serviced the boiler and replaced the thermal coupler. the unit is about 10 years old and is used for radiant floor heat
laars lite 2 pool heater heats and then stops I checked the temp sensor and it is fine. Is this the...
(More)
laars lite 2 pool heater heats and then stops I checked the temp sensor and it is fine. Is this the temp controller?
I am winterizing my Laars Lite2 pool heater and have what may seem to be easy questions but... What...
(More)
I am winterizing my Laars Lite2 pool heater and have what may seem to be easy questions but... What Do I grease the drain plugs with before I put them back after draining heater?. Should it be Silicone based? Also where do I blow the compressed air to dry out heat exchanger?.. Thru the drain plug holes? Thanks
I have a Laars LX400 heater. Yesterday the heater would not start - Hi Lim SW error. I replaced...
(More)
I have a Laars LX400 heater. Yesterday the heater would not start - Hi Lim SW error. I replaced both of the limit switches. Now when I start the heater, there is no sound for a minute or so and then I get "Air Flo SW" error.
http://johnstonesupply9.com/TechDocs/Goodman/Furnaces/GMV9%20Variable%202-Stage%20Upflow%20Gas%20Furnace/GMV9%20Service%20Man.pdf After giving up on...
written by lallen_rgmv4
Traditional water heaters use a storage tank to hol... Read More
Traditional water heaters use a storage tank to hold heated water until it is needed. They typically run off of natural gas, but electric and propane heaters are also common. In addition, tank less water heaters are available. They operate by routing water to where it needs to be instead of storing
