20 Most Recent
Dimplex DS5629 Electric Heater Questions & Answers
Just purchased a dimplex DS5629
Ar e you sure that the receptacle your have it plugged into is working? If it is, you can try this. It usually works. Turn the Master On/Off Switch to OFF. Unplug the unit and leave unplugged to 12 - 15 minutes. Plug the unit back in and turn the Master On/Off Switch to ON. Then, turn each individual function one at a time. If they ail function as they should, the unit has reset itself.
If it doesn't work, then you'll have to wait until Monday to contact Dimplex OR you could contact the retailer you purchased it from and have them replace it immediately. That is, unless you purchased it online. Then, it would be better to wait until Monday and contact Dimplex. Be sure you have your Model Number and Proof of Purchase, when you contact them. In case you don't have it, their Technical Support number is 888-346-7539.
Hope this helps you solve the problem.
Have a Dimplex dfb6016 electric heater that needed a new power cord. Bought one, but one end has the cord and blue wire fused together. I need help.
If the cord you purchased has a blue wire fused with the cord, you will need to cut off the fused portion and strip the insulation from the end of the blue wire. You will then need to connect the stripped end of the blue wire to the corresponding terminal on the new power cord.
If you are not comfortable doing this yourself, it is recommended to consult a qualified electrician or appliance repair technician to complete the wiring safely and correctly. It is important to ensure that the replacement power cord is compatible with your Dimplex dfb6016 electric heater to avoid any potential safety hazards.
